My diesel is difficulty to start on cold cold days. it also will have a large amount of ssmoke after cranking
First, for poor starting from cold, you need to check the heater plugs, to do this, remove the wiring to each heater plug, then get a piece of wire/cable and get another person to help, you need to hold one end on the top of the heater plug, where the wire was connected, and get your assistant to flash the other end of your wire on the positive terminal of the battery, now, if there is a spark, then that heater plug is ok, if there is no spark, then that heater plug is faulty and should be replaced, do this to all heater plugs, and replace as necessary. Ideally , if just one is not good, then i would advise to replace all..
As for smoke from start up, all diesels will smoke on initial start up but it should clear when warmed up. However, if you have constant smoke, presumably black smoke, then you should check the air cleaner and hoses first, that the filter is clean and that the hoses are not blocked, split or collapsing when you give a bit of revs to the engine. The next step would be to check the fuel filter,if it has a drain plug, then undo that and see if the fuel is discoloured or you see any debrit coming out, it would be wise to change this , unless it has been changed recently. If you still have smoke, then you need to get the injectors checked, this can only be done by a diesel fuel workshop. Hope this helps
