Question about JVC AV-65WP74 Rear Projection Television
Convergence hi....... i have a 65in tv.....i have changed the 2 ices stk........its good now...but the convergence is not very good.when i try the manuale conver.... the lines of colers do not go with each other if you fixed the uper lines the dowen ones go so rong........i hope you can help me.....thanks alshareef1973@hotmail.com
  • JVC Master
  • 8,617 Answers
Did you replace the convergence resistors with the ICs? The resistors often get increased resistance when the ICs go out and if they dont get replaced you can have a next to impossible time adjusting the convergence properly, as they have to be within 5% tolerance. You can get the resistor kit for your JVC at the following link. Its Called JVC convergence resistor kit #1. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 09, 2008
Focus Error I am getting double picture and the colors are off. When trying to auto focus the blue lines are wavy.
Replace Convergence ICs ,Big black ICs will have PN# on them example STK 392-110
Mats has ICs 1-800-628-1118
Jun 05, 2011 | Toshiba 42H82 42" Rear Projection...
Tip
Convergence
on Jul 02, 2008 | JVC AV-65WP74 Rear Projection Television
I changed my two IC chips and three resistances on my Hitachi TV to fix color alignments. Now the problems is that yellow and blue double image are seen at the bottom of my screen with no much effect on...
Ur tv still have dead resistors parts,test all 12 resistors parts around the 2 STK convergence ICS and changes some more dead resistors parts or changes all 12 resistors parts for sure.If tv still have the same problems after tested and replaces more resistors parts or all 12 resistors parts.Than some how when u handling and replacing the 2 STK convergence ICS and resoldering the 2 STK covergence ICS u short it out the 2 STK convergence ICS by resoldering without proper grounding ur self not to allow for static electricity to kill the 2 STK convergence ICS or u using a soldering iron to high of a wattage for doing soldering ICS work.
Apr 23, 2011 | Hitachi 43FDX01B TV
The tv looks like it is in 3d. when i try to adjust the convergiance the plus signs on the left are bent
do not play with this tv replace the stk ic chips and the resistors around the stk chips ,cant miss em about 2 inches big with heat sinks on them.
Sep 11, 2010 | JVC AV-48WP30 48" Rear Projection...
Hi I have a teac CTM809SV crt tv and on any av input displays a blue and green color. Will pick up the channel ok but with a purplehaze.have tried turning off for 10 minutes but no luck-any tips...
Ur tv have a convergence problems.It dead.The tv convergence board require 2 STK convergence ICS and some or all it resistors to change to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 29, 2010 | Hitachi 43UWX10B 43" Rear Projection...
The color is out on my tv
U mean all ur colors picture lines on the tv are misaligns?Ur tv convergence are dead.This problems are the 2 STK convergence ICS and some or all it resistors are dead.The convergence board the 2 STK Convergence ICS and those resistors must be change to solved the convergence problems.The shop will cost u $300-350 for the parts and labors.
May 18, 2010 | Pioneer SD-532HD5 53" Rear Projection...
Color will not match up
if your talking about the sets convergence does not line up and it looks like a 3-D picture than The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! Go to http://www.tvrepairkits.com/xcart/home.php?partner=larry
The kit comes with original Sanyo STK IC'S , not those cheap aftermarket or china made IC'S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon.
http://www.fixya.com/support/r3342653-convergence_fix
May 08, 2010 | Hitachi 51UWX20B 51" Rear Projection...
Unable to perform convergence.
Ur 2 STK convergence ICS,and some or all it resistors are dead.U must know how to solders?Replaced the 2 STK convergence ICS and some or all it resistors,will auto focus ur convergence back to normal buy itself.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Mar 10, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
Panasonic PT-51HX40B convergence issue
Hi.....
Bit of a long shot but have you tried this??
http://oreilly.com/catalog/htheaterhks/chapter/hack12.pdf
Hope it helps!
Richard
Apr 28, 2008 | Televison & Video
Colors separated
You need change STK392-560(can use STK392-570)
I guess it happend when holding bolts weaken to radiator.(Check other STK on next radiator)
You have to change STK on right radiator.
Disconnect small connectors. You can l leave Hi Voltage two lines(RED). unscrew board.
Pool board out.
Unscrew STK. Set board verticaly. Just pool STK bu pincet and heatup solder. One by one...
Clean halles.
Set new STK with thermopasta on board in to hallsradiator. Screw up.
Wet contacts by liquid fluse. And sosler them.
Clean up by alcohol...Check for short by lense...
Apr 28, 2007 | Sony KP-57WS500 57" Rear Projection...
JVC AV-65WP74 Rear Projection Television Logo
57 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
