Boss Micro BR Digital Recorder Logo
Posted on Dec 14, 2010
I have recorded 4 tracks and a rytham arrangement but when i try to convert to MP3 i get no drums?? Any ideas
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
135
Points
For the drums to take effect you have to master the track before converting. The manual explains how to do this. Push "exit" and "utility" at the same time twice, then "play" and "record" (to start the recording of course).
How do I transfer track data to computer?
Why you have to convert to mp3 ?. Did not the card can be removed and installed on the computer and then copied?
Where you convert the file? BR or computer?
What software you use to convert?
I recorded drums to the internal click track/metronome and drums are in time with metronome when i play it back with the click from the start of the song. BUT, if i stop in the middle of the song and...
I'd say the click track starts from exactly when you hit play even if you've hit play not right on the beat. There might be a setting or preference that can fix this.
Try rewinding back to be right on the beat and see if it syncs with the click
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
I can't seem to figure out how to record one track over another without a delay problem? I am using the behringer 1202 mixer into my computer. No problem recording but can't do multiple tracks. I'm new...
This is a common problem with digital recording. Simply put, it takes some time to convert analog (audio) to digital and then more time to convert it back. So, your playback track goes through conversion and introduces some delay. You don't hear this because you have no zero reference. Your recorded sound goes through the A/D converter and also incurs some delay. When you play them back together, you hear the difference in time from one track to another. Most pro recording programs have some method to minimize or cancel the delay like slipping the tracks so they all start together. Pro Tools just introduced a version that automatically does this. They have always had what it called "low latency" monitoring which attempts to keep the "shortest" digital/analog path so overdubs are close enough that we don't hear any issues. So, since you talk about the mixer but not the recording program, I can't tell you specifics but I'd look into the recording program for time alignment settings and options. If you have a manual for the recording program, try to look up latency.
Maybe stupid question....is it possible to record 8 separate mono tracks on this thing? I cannot seem to select only track 5, 6, 7, or 8. When I try to record onto 5, for example, it is impossible to not...
I believe you have to adjust the levels DURING the bounce operation... I don't think you can do that after.
I would consider using a computer based editing program to handle more than 4 tracks...
I want to record vocal voice trhought mic on psr 9000
You could record short "samples" to be used in building new voices, however, it does NOT appear that you can record a vocal song with the PSR9000. The Tyros II and III have the capability to record vocals but the PSR9000 and Tyros I do not..
When playing back an arrangement, you can re-sing the song and have the vocal harmonizer track the arrangement.
8helpful
2answers
Boss micro br not converting all the tracks in the song to MP3
You have to "mix" the tracks to create a final work before saving the file.
I need help with my Boss Micro BR. I want to convert the song I recorded to MP3, so that I can hear it on my laptop. I connect the recorder with the laptop through U.S.B. and can only get to the files that...
Go to bossbr.net - Plenty of answers there! And yes, you have to master or export the tracks to .mp3 or .wav. These files will be located in the mp3 folder. Boss also makes a free .wav converter located on their website.
1helpful
2answers
When bounce tracks on my micro-br there seems static going on
First of all, it would be better for you to pan the tracks, and bounce into 2 tracks for stereo separation.
Your "static" may stem from three pausible causes.
One, four tracks into mono may make your output a little muddy.
Two, watch the reverb - if you keep applying reverb after each bounce, it starts to sound bad.
Three, if you have drums/rhythm, turn it off while bouncing. Only have drums on when mastering, because they will keep getting re-recorded during bouncing.
Go to bossbr.net - The best place to get answers!!!!
Top Boss Music Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a Boss Music Expert? Answer questions, earn points and help others
