Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer I brought a whirlpool top load washer from USA & in india, 3 techies have ruined it...the last guy said I need a new controller so i got one from usa...have misplaced his number , need a whirlpool service agent in bangalore...psl advice.tahnks.
    Problem Solver:
  • 15 Answers
Try getting a bottom load washer
Posted on Jul 13, 2008
Code "F1" pops up most of the time, spin the
F1 is a pressure sensor failure in the machine control board.This is a well known issues with whirlpool washers their is even a service bulletin concerning this problem, To make a long story short the MACHINE CONTROL BOARD needs to be replaced.You may and should contact whirlpool to see if they will offer assistance in this repair as the part is expensive (around 300.00 dollars) After having it repaired make sure to use HE detergent in the proper amount, to much soap suds can travel through the pressure sensor hose directly into the machine control board and ruin the new computer Hope this helps good Luck
Dec 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code F 33 on whirlpool duet waher. Sevice guy
i think that has to do with not filling .. does water enter machine. is it filling slow?
Apr 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Nov 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Timer dosent count down
HI, this is a simple fix here, you will need to replace the timer/control module. this will fix this issue. this specific device is ruined and, unable to initiate the wash cycle correctly due to circuit damage.
May 18, 2009 | Whirlpool Calypso GVM9959K Top Load Washer
Whirlpool front loading washer and dryer F28 keeps coming up
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Mar 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Ultimate care II 3 buttons on top
Called my repair guy, who is always helpful. He told me if it wasn't the motor coupler it was the transmission. He said he could rebuild it for around 80-150$, in my opinoin he is a good honest person, never does me or the many people I know any wrong. He said their was no telling how long it would last. I have a family of 5, the washer is almost 10. I went out and bought a new one. My parts guy recomended I buy the same brand Whirlpool, with a direct drive motor. I took his advice and got a new one with the same type of motor. I stripped down the old one, kept the motor, dog ears, motor coupler, and the water pump. Hopefully those parts will save me some money. The dog ears and motor coupler, I just replaced them within the last couple weeks. My parts guy always says "lighten up them loads" and it is good advice as I always replace dog ears every 6 mos. But at 8$ a pair it's an easy fix. Having a reliable parts man, who explains how to fix everthing- PRICELESS. Anybody in SE Michigan should stop by Richard Bros. Appliance in Riverview, MI, they do service calls as well. Thanks-Scott
Jan 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Cabrio code F50
I also had an F50 code on my Cabrio top load washer. Went through all the diagnostics, removed the tub, checked the motor, etc. After a lot of research, purchased a new control board (part #W10189966) and....it works even better than before....no more noise and spins perfectly. Very easy to install (3 screws and one bolt.) Please don't waste your time (like we did) checking all these other areas of the machine. The part was $155. (google it for best price new) and worth it if it will last another year or more...
Nov 08, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio top load washer has ruined towels and shirts. Shreds them. Also sheets are balled up and twisted into a mess that takes time to unbind..hate this washer
Whirlpool has made a few improvements over the past few months regarding motor operation and wash issues.
  • The RPS (Rotational Position Sensor) connector design has been improved, providing a more reliable connection to eliminate the F51 error code and is available as a service kit.
  • The electronic control has also been updated for better sensing of the RPS.
  • If you have experienced problems with certain wash loads getting tangled and knotted and ruined, there is an updated washplate design intended to reduce these issues.
You should contact Whirlpool for possible repair concessions related to these issues. Phone numbers will be in your owners manual.
If you need further assistance, let me know
Regards,
reg501
Jul 05, 2008 | Whirlpool Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
133 people viewed this question
Dan Webster
Dan Webster
Sal De
