SOURCE: DGS-3024 Gigabit-Ethernet Switch
Open a web browser an put the IP address of your switch in the addresse bar. Once in the web interface, open the Monitoring folder and then click the Port Utilization link. The switch is actually creating graphics of each port utilization.
Much more details are provided in the user manual:
http://support.dlink.com/products/view.asp?productid=DGS%2D3024
Click on the "Product Manual" link at the left.
SOURCE: ''!!! WARNING: The switch is not usable !!!''
Unfortunately the show stack isn't showing any results other than it is either a hardware or software fault. I am guessing it is a fault with the hardware as the show version in your first post states "interface Ethernet-controller 4 failed POST POST error status : general error occured".
Ethernet-controller 4 is one if the gigabit ports (poss fibre port), so if you have anything attached to those, disconnect and reboot the switch and see what happens. If that doesn't work, you could try reinstalling the IOS, but at a guess I would say its a hardware fault.
SOURCE: Routing vlans on 3com switch 4500
i can't set ip address over 4 vlans. the 3com switch 4500 always give error message "there's not enough routing resources available".please help....
SOURCE: I have forgot my admin
Search the following documents for 'Password Recovery':
http://support.3com.com/infodeli/tools/switches/4500/s3n03_01_00sp01_readme.pdf
http://support.3com.com/infodeli/tools/switches/4500/3Com_Switch_4500_Command_Reference_Guide.pdf
Both of these document discuss the password recovery process for this device.
