Question about Acer Aspire 5315 Notebook
Battery is not charging. When i plug the charger into laptop it doesnt charge. the battery light flashes orange and the other light which has an illuminated bulb next to it turns orange too. Do i need to change the DC Jack?
    New Friend:
  • 130 Answers
This is a common problem with Batteries and AC Adapter you need to check, maybe your battery cells are dead or AC failing voltage
Posted on Dec 14, 2010
SOURCE:
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
I just replaced my laptop battery - BATBL50L6. My charge light flashes orange. Win7 says plugged in, not charging. shows 0%. I tried reinstalling the ACPI battery monitor in DM.
try putting the old battery back in and see if you get the same problem. Also check where the chargers plug goes into the laptop. If it fits loosely your charger port needs replacing.
Apr 02, 2011 | Acer BATBL50L6 Laptop Battery
My Sony Vaio battery light remains orange
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 26, 2010 | Sony VAIO Notebook
Laptop suddenly stops recharging / recognizing the charger
Here is a manual....mostly replacement parts etc.
http://tim.id.au/laptops/toshiba/satellite%20and%20pro%20220%20440%20460%20470%20480.pdf
Sounds like your battery is shot, bad or discharged or shorted batteries will shut the charging circuit off.
Oct 16, 2009 | Toshiba Satellite Pro 470CDT Notebook
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Ds is plugged into charger. But when i try to
What is the orange charging light doing? If it is just flashing on, or only staying on or a minuet, that means you need a new battery. The orange light foes on when the battery has been charged to its maximum capacity. After each charge, the capacity is decreased. So if the orange light is on for only a short time, get a new battery.
Feb 28, 2009 | Nintendo DS Lite Console
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
The Charger light flashes orange 3x and green once but it wont charge
Your battery has died, of a fail safe has kicked in. The orange light indicates that the battery isn't charging properly, and needs replaced. Replace the battery and it will be fine. Keep in mind that batteries are just batteries, they eventually wear out, and some faster than others. Also, the more you use the battery, the faster it will wear out, so I always recommend keeping the machine plugged in when possible.
Aug 25, 2008 | Dell Inspiron 8000 Notebook
Acer Aspire 5315 Notebook Logo
684 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
