Question about Motorola Mobility RAZR V3m Cellular Phone
Can not receive any signal
My phone can not receive any network...I tried switching to other sim cards but it can not pick up any signal. pls help. thanks.
  • Anonymous Mar 14, 2009
    i have a sony ericsson w580i and i am unable to receive any signal ... i tried the sim on a different phone and it worked fine ... the service centre said the whole board has to be changed ..
    Sergeant:
    Champion:
  • 417 Answers
Maby your not in a good signal area for that network
Posted on Jul 05, 2008
    Master:
  • 726 Answers
Mm have u ever dropped the phone or any thing like that if it cant pick up any signal sounds like the internal areal has broken or faulty thats all it could be
Posted on Jul 01, 2008
Phone is locked emergency calls only
Did you mean your new used phone shown Emergency calls only while inserting your metro pcs sim card?
Yes means, There are two possibilities to get this type of issue.
1.You mobile phone receives weak signal from near tower so try to Switch off your mobile,wait few seconds and switch on.
2.Your mobile is locked to particular network provider.
If your problem persists after switch on your phone means definitely your mobile phone is restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your phone visit http://www.theunlockspot.com/samsung/rs10wp8/ I hope it will be very useful to you.
Sep 11, 2014 | Samsung SGH Cell Phones
About aircel sim card
pcb board how to find tracking
Dec 10, 2013 | Nokia 1100
I have nokia n70 but i cannot received and sent text messages nor cannot make a call keep saying network busy. please help me this.
1. Turn the mobile phone off for a second and turn on, check if you have network signal. If still not working, try #2
2. Turn off the phone and remove the battery and sim from the phone for a couple of second. Return everything and turn on the phone. If still no network or no signal from you network provider, try #3
3. Turn off the phone and remove the battery and sim from the phone, insert the sim card to your other phone and check if you can make and receive calls and text messages.
4. Insert a your other sim card from your phone and check if you can do the same.
**With this, you can identify what needs to be repaired or replaced. (Sim card or Mobile Phone). If you cannot make and receive calls and text messages using no. 3 method, it is the sim card that has the problem and needs to be replaced. But if with #4, the phone has the problem and not the sim card. You need to contact your Service/Network Provider from technical help.
Thank you.
Aug 10, 2010 | Nokia N70 Cellular Phone
Nokia N79 network Problem
Your sim card might have died. Turn off phone and pop out sim then turn phone on and off. Pop sim back in and try phone. You can allso go into settings and do a phone resett.
PS: Make sure you didn't put it in airplane mode by accident.
Jan 29, 2010 | Cell Phones
MY samsung jet (no network
try to do these steps:
1. switch off your phone, remove battery, sim and memory card.
2. reinsert your battery and switch on your phone.
3. on your keypad menu type this code to make a hard reset. *2767*3855#
4. after hard reset, reinsert your sim, battery and memory card and check.
you may also want to try these.
1. remove your sim and have it check with other phone if it's receiving a signal.
2. insert another sim to your phone and check if it will receive a signal .
3. check your phone profile settings, press menu, select settings, select phone profile, select normal mode and check if it will give you a signal.
if you found out that your sim has defect, you may buy new sim and replace it, but if your phone has the problem after all of the above steps, go to your nearest samsung service center and have it check. if it's still under warranty, you may want to consider returning it your phone dealer, where you bought it, and have it replace with new one.
good luck and take care...
Jan 11, 2010 | Samsung Jet S8000 Cell Phone
My Xda Zinc displays no network service all the time. I already tried changing sims but none of them has network signal. i tried the soft and hard resets but still doesnt work. I cannot call, txt and even...
My Xda Zinc displays no network service all the time. I already tried changing sims but none of them has network signal. i tried the soft and hard resets but still doesnt work. I cannot call, txt and even received messages. need your advise. pls. help.
Nov 06, 2009 | O2 Xda Zinc Cellular Phone
it is the problem of pfo so u have to change the pfo go to ur nearest care center
Mar 14, 2009 | Sony Ericsson w580i Cellular Phone
The phone is not picking network signals
just try this
when ur pda is switched off press Call and end key together and then press power button for like 5 sec a screen will appear asking u to format the pda pls confirm the action by pressing center button of the 4 way keys and then ur pda will be factory reset to the default OS , if it helps ur problem then tell me
other wise go and upgrade ur ROM from www.htc.com it will help u for sure basically it is a software issue
have u tried other sims in in it like warid or telenor or jazz try them and tell me i can help u
pls rate me fixya for help i have provided
Mar 01, 2009 | HTC Touch P3450 Smartphone
Solution to my problem
hi there!
Simply, tap your device and go to Connections > check the networks and let you select the networks manually and automatic. if still doesn't work, Insert your sim card to other mobile phone and see if you still don't have your signal. Maybe the sim card was damaged. If not, perhaps the phone has it. Anyway, does your phone locked to another network provider? pls check.
thanks!
Feb 19, 2009 | i-mate JASJAR Smartphone
Changed service, can't receive a signal
ATT runs off of the 850 mhz bandwith while tmobile uses 900. The old phone you are using uses tmobiles bandwith and only catches 850 occasionaly. I would suggest trying to get an upgraded from ATT when you signed the contract
Sep 26, 2007 | Sony Ericsson T610
Motorola Mobility RAZR V3m Cellular Phone Logo
131 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
