Question about Canon Office Equipment & Supplies
PGBK cartridge on Canon MP530 won't stop flashing. I have replaced the cartridge with new but remains flashing and won't take a print command.
    Genius:
  • 2,785 Answers
Plz clean the cartridge and head contact point and try, if the problem persist then try with another set of ink
Posted on Jul 01, 2008
My PGBK ink cartridge is not printing. I just replaced it. Everything else is working fine. I have done several cleaning jobs on it and the test prints that I print don't even show PGBK or the black...
the PGBK ink cartridge might not be getting a good connection you might have to remove it and check the connections or clean the connection bars
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you
might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Oct 21, 2011 | Canon Pixma iP4500 InkJet Printer
Will not print text from computer (paper feeds
PGBK cartridge was totally blocked. Deep cleaning did not resolve block. Replaced ink cartridge (large black).
Feb 07, 2010 | Canon PIXMA MP160 All-In-One Printer
Hi, My printer says it wont print. the cartridge light is flashing On top it says Pgbk (On the screen it says PG1-SBK The remaining f the following ink cannot be correctly detected - black. What do I do?...
some printer s have timer chips in the ink cartridges i have new epsom cartridges only used once now wont reconised due to the chips you may need to replace cartridge you could try removing the cartridge and reinstalling it to make sure it has good connections
Jan 17, 2010 | Canon Pixma iP4500 InkJet Printer
The PGBK cartridge seems to be leaking and leaves a smear of ink all the way down the paper on the opposite side of the print.
That's ink from the cleaning station backing up thru the exit rollers. You need a shop to clean up the extra ink and install a shield that will prevent that in the future.
Nov 04, 2009 | Canon PIXMA MP530 All-In-One InkJet...
MP530 PGBK not recognized
1. UNplug printer at outlet or power strip & wait a full minute.
2. Plug back in and check if ok now.
1. remove cartridge; look for "spit wad" stuck onto the cartridge or in the cartridge cavity in printer.
1. If of the above neither works; use a new cartridge, but don't discard old one.
Sep 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
How do I get my first blank ink cartridge to work?
you really need to replace the empty cartridge...it's a protection for keeping your printhead from drying or else the micro nozzles will be clogged with dry ink. did u try setting the printer settings to use greyscale or black and white only?
Aug 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
PM530 printer: PGBK cartridge not working. Just
Clean the feeder use Que tip With Alcohol only let it dry and clean the cartridge the same way replace the That should solve the problem, Also keep in mind if you are using a cartridge that is a refill The cartridge sometimes dry out Have that checked it might be bad other words plugged up. Good luck with it
Feb 21, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Nozzle Blockage in Canon MP530
i hope you dont mean a snooker/pool q tip??
i would say to replace the printhead, this can be found on google.
part number is: QY6-0059-000
Oct 17, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP500 PGPK cartridge wont print
i have the same problem too. This is obviously a product defect. If Canon not fix it, i wont buy Canon printer anymore.
May 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
More than "one ink catridge installed" problem with new printer
Try a new Genuine yellow ink in it, if it fails take to canon dealer for free warranty repair.
Jan 12, 2008 | Canon PIXMA MP530 All-In-One InkJet...
98 people viewed this question
old marine
old marine
