Question about Refrigerators
GE/Hotpoint fridge leaking water on floor.
The fridge is over 20 yrs. old. It is a frostfree dual sided appliance.
Leaking water from the inside (bottom ) wall on the freezer side. Not inside the freezer compartment. The water input is turned off and the water/ice maker are off. The water appears in the fridge frame track, and not in the water catcher tray. It seems to happen sporadically, like when the unit is defrosting. It seems to be inside the outer wall and the freezer wall. All hoses are intact and not leaking. A rust spot (size of a quarter) has appeared on the outside freezer side wall; about the same height from where it is leaking on the inside wall.
  • woodhamr Jul 17, 2008
    I ahve the same thing. 20 years+ GETFX24RF. Leak developed from what appears on the floor to be from the freezer side. ICe maker water supply turned off. Drip tray not over flowing. We never use the water or ice on the front. What is the fix? How much (ball park)? Thanks.
  • Anonymous Aug 22, 2008
    Water is leaking from the inside of the top part of the refrigerator. It is coming out near the switch for setting the freezer temperature.
5 Suggested Answers
  • 1073 Answers
SOURCE: Maytag side by side refridgerator
the drain tube is clogged or maybe frozen, remove the restriction and you will have no more problem
Posted on Apr 10, 2008
gaeb7
  • 25 Answers
SOURCE: hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
Posted on Mar 01, 2009
jumptrout51
  • 3361 Answers
SOURCE: leaking hotpoint 21.7 cu. ft. csx22bc
Your defrost drain outlet is frozen over.
Turn off the fridge.
Remove the bottom drawers.
Look in the back section just below the back freezer panel and you will see an ice dam.
This must be defrosted. Use a hair dryer.
Once all the ice is gone pour water into the drain to make sure it is clear.
Then pour a 1/4 cup of bleach in the drain.
Turn the fridge back on and you will be OK until it happens to stop up again.
SOURCE: ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Posted on Nov 07, 2009
Water collecting inside fridge, under meat drawer
Yes most responses are the freezer drain even if it is in the bottom freezer. If the drain is blocked water will build up anywhere inside your refrigerator only because it has no place to go during the defrost. Defective door seals can also can make the problem much worse. See Leaking Refrigerators I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | GE Profile 22.2 Cu. Ft. Side-by-Side...
GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Aug 14, 2012 | GE Refrigerators
Ge side by s
Oct 26, 2009 | GE Refrigerators
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ffa97g/frostfree
remove back panel inside freezer and you will find drain at bottom blocked with ice. melt off with a hairdryer and follow up with hot water till drain flows freely.
you may have a fault with the defrost system or the drain heater
Sep 09, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
GE side by side leaks water onto floor, no ice
There is a pipe that runs up the back of the appliance and feeds the ice maker , if this freezes inside then it canpush the fitting off the back of the appliance and cause water to go everywhere. Usual problem is a leaky watervalve causeing water to drip into the pipe which freezes and builds up until it is totally blocked.
Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
552 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
