Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Top loader
I have replace all seals, bearing, but the drum do not turn when the spin action is on. I can not remember where the spring of the brake must come on.
    Problem Solver:
  • 15 Answers
Chin Sao mua te quempo
Posted on Jul 13, 2008
We keep getting the UL (unbalanced load) code on our Whirlpool Cabrio washer (model # WTW8800YC1). Is there a way to determine if it is the bearings or the suspension rods?
You can check the bearings by axially moving the drum against the axis in which it spins, backwards and forwards on a top loader, or up and down on a front loader.
More likely to be a suspension spring broken, or come unhooked.
Try the washer with two bath towels to check for uneven loading.
Dec 29, 2016 | Whirlpool Washing Machines
Washer drum making loud noise when spinning
Reach into the drum (on a front-loader)and push upward to see if it moves at all, you should feel no play where the drum support shaft passes through the bearings... The bearings will "roar" loudly during spin if the main seal has leaked water into them... Top-load washers will exhibit the same roaring if the seal fails in them also. Whirlpool Tub Seal and Bearing Kit W10435302
May 13, 2016 | Washing Machines
I have a kenmore frontloading washer, during the spin cycle a noise like grinding can be heard, grinding can also be heard when turning drum by
its the drum bearings that support the inner drum,you need to replace these bearings,the problem with this is it was manufactured by frigidaire for kenmore and you cant just buy the inner bearing and lip seal as it comes with the outer rear half of the outer.tub where as with maytag neptune or whirlpool duet you can drive these bearin gs out and re-use the tub half,but you can't buy just the bearings and seal for a frigidaire front loader
Aug 31, 2012 | Kenmore Washing Machines
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
Either one of your springs have broken at the top of drum.
Or the dampers under the drum have failed.
Possibly both.
You can get to your top springs by removing lid.
Dampers access is via the underside.
Remember to disconnect power and water before opening up machine.
Please dont forget to vote if you liked my answer
Feb 09, 2011 | Washing Machines
Bearings are loud when drum is spinning
well if its a front loader or a top-loader washer sometimes the parts are covered under warranty parts only.....check 2nd threw fifth year warranty in owners manual can be almost the cost of a new one if parts aren't under warrantty .... and most top-loaders require a spanner wrench a specialty tool to perform repair.... usualy seal bearing average $60.00 to 120.00 dollars each and around $ 130.00 in labor sometimes more for top loaders and ... frontloaders it usually requires seal rear tub with bearing and spider drum support bearing usually$60.00 rear tub with seal $160.00 an upto $225.00 and spider support $80.00 an up to $160.00 thats just parts we havent even got to labor ..... labor about 2 hours....depends on local rates...
Jan 31, 2011 | Washing Machines
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
Whirpool top loader unbalanced spin cycle
First change the springs - both the leveling and suspension. You may also need to change a few other parts on the brake and drive tube including the thrust ring. But replace the springs and let see what happens.
Post your results . Remember to rate this solution
Jul 27, 2008 | Whirlpool LSB6200KQ Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal De
