Question about Toshiba Computers & Internet
My notebook computer is failing to start up - Toshiba Computers & Internet
  • habite113 Jul 01, 2008
    I own a toshiba tecra purchased in 2005 and am using windows XP. The notebook is failing to start up. My screen doesnt light up at all. Help????
    Genius:
  • 2,785 Answers
If you can see the bios then try to boot in safe mode other wise you have to resit the ram
Posted on Jul 01, 2008
90B fan error
Start your notebook and start tapping the F2 key. In the diagnostic screen perform the hard disk diagnostic. If the diagnostic reports a hard disk smart test fail, then your hard disk is failing and must be replaced. That is the only way you will be able to return your notebook to useable condition.
If hard disk is ok I suggest you goto HP support Forums at
http://h30434.www3.hp.com/t5/Notebook-Lockups-Freezes-Hangs
Jan 23, 2014 | HEWLETT-PACKARD Pavilion dm4-1265dx...
Tip
Limited or No Connectivity
<b>Hardware works but wireless doesn't and you're getting the limited or no connectivity error.</b><br /> <p><b>Please note:</b> This document assumes that you have checked that the wireless NIC is turned on and that the Wireless Service and DHCP Service have been checked and that they are both enabled on the notebook and the services are running.<br /> <b>If you're unsure about the services do the following:</b><br /> 1. Start &gt; Run &gt; 'services.msc'<br />2. Search for DHCP Client in the services list. The Status should be Started and the Startup Type should be Automatic. If not, right click on the service choose properties and fix the Startup Type to Automatic. Click OK to close the window.<br />3. Search for Wireless Zero Configurations. The Status should be Started and the Startup Type should be Automatic. If not, right click on the service choose properties and fix the Startup Type to Automatic. Click OK to close the window.<br />4. Close the window<br />5. If you had to restart any of the services, reboot the computer.<br /> <b>1. Update wireless driver</b><br /> Boot the computer into safe mode with networking.<br />Hardwire the notebook to the cable/DSL modem,<br />Uninstall the drivers and utilities for their wireless card.<br />Customer should go to the manufacturer's website and download the latest wireless driver revision for their notebook.<br />Install the latest driver.<br />Shut down the computer and unplug the LAN connection.<br />Reconnect the router and modem.<br />Wait for router and modem to sync.<br />Boot the computer again.<br />Test the connection.<br />If the connection fails go to step 2.<br />If the connection works resolved.<br /> <b>2. Winsocks fix</b><br /> <b>Start &gt; Run &gt; 'cmd'</b> enter<br />Type in the following:<br />netsh winsock reset<br />Computer should need to be rebooted<br />Test computer after reboot<br />If the connection fails go to step 3.<br />If the connection works resolved.<br /> <b>3. Power cycle the router</b><br /> Unplug the router and let it sit for 30 sec.<br />Power down the notebook.<br />Plug the router back in and wait for all the lights to stabilize<br />Reboot the computer.<br />After the computer makes it to the desktop test the connection.<br />If the connection fails go to step 4.<br />If the connection works resolved.<br /> <b>4. Confirm that the connection is set to b or g (depending on router)</b><br /> <b>Start &gt; Right Click 'My Computer' &gt; Manage &gt; Device Management &gt; Network Connections &gt; Right Click on the Wireless NIC &gt; Properties &gt; Advanced Tab</b><br />Click on Wireless Mode under property<br />Make sure that it is 802.11g or 802.11b depending on the router.<br />If the connection fails go to step 5.<br />If the connection works resolved.<br /> <b>5. Move the notebook closer to the router (within 3 feet or less).</b><br /> In some cases the antennae may be damaged or disconnected from the Wireless NIC.<br />Verify that the wireless antennae are connected to the wireless card by going under the panel and looking for them.<br />If the connection fails go to step 6.<br />If the connection works resolved.<br /> <b>6. Check for encryption</b><br /> If encryption is there can it be cleared?<br />Y. Clear settings<br />Hard reset the router (usually involves holding down the hard reset button for 30 sec and having the router go back to default settings).<br />Disable encryption keys on the notebook.<br />If the connection fails go to step 7.<br />If the connection works resolved.<br />N. Do following<br />Hard reset to factory default (to clear any configuration setting that the customer may have set up).<br />Insert the WEP/WPA key using generic setup (on connections)<br />If the connection works resolved.<br />If the connection fails - go to advanced setup<br /> <b>Advanced Setup:</b><br /> <b>Go to Start &gt; Control Panel &gt; Network Connections &gt; Right Click on Wireless &gt; Properties &gt; Wireless Networks &gt; Click on //Network Name// &gt; Properties<br /></b>Select WPA-PSK<br />Set Data Encryption to TKIP (if not already selected)<br />Enter Network Key (confirm case of letters)*<br />Confirm the key<br /> Click OK<br /> *Note: copy and paste does not always work ... type the key in manually!!! (garbage characters can exist in a copy and paste or spaces may appear!!!)<br />Test the connection:<br /> If the connection fails go to step 7.<br />If the connection works resolved.<br /> <b>7. Mac Filtering</b><br /> Hard wire the notebook and verify that MAC filtering is not enabled on the router.<br />If it is disable the filters and test the connection.<br />If the connection fails go to step 8.<br />If the connection works resolved.<br /> <b>8. Verify Channels</b><br /> <b>Start &gt; Right Click 'My Computer' &gt; Manage &gt; Device Management &gt; Network Connections &gt; Right Click on the Wireless NIC &gt; Properties &gt; Advanced Tab<br /></b>Under Property choose Channel <br />Make sure that the Channel is the same as on the router.<br />If unsure:<br />Connect via LAN to the router and look up the channel that it is using.<br />If the connection fails go to step 9.<br />If the connection works resolved.<br /> <b>9. Disable Firewalls</b><br /> Check to make sure that the firewalls are disabled. In some cases these can interfere with connections being made to the router. <br /><b>Start &gt; Run &gt; MSCONFIG</b><br />Disable all startup items<br />Reboot the computer<br />Test the connection.<br />If the connection fails:<br />Uninstall all firewall software and disable the XP firewall.<br />If the connection works resolved.<br /> <b>10. Router firmware update</b><br /> Conference in router manufacturer and explain the issue and tell them WHY an update is necessary (no communication between router and notebook).<br />
on Mar 15, 2011 | Computers & Internet
Tip
Wireless - Limited or no Connectivity
Hardware works but wireless doesn't and you’re getting the limited or no connectivity error.
Please note: This document assumes that you have checked that the wireless NIC is turned on and that the Wireless Service and DHCP Service have been checked and that they are both enabled on the notebook and the services are running.
If you’re unsure about the services do the following:
1. Start > Run > ‘services.msc’
4. Close the window
2. Winsocks fix
Start > Run > ‘cmd’ enter
netsh winsock reset
Start > Right Click ‘My Computer’ > Manage > Device Management > Network Connections > Right Click on the Wireless NIC > Properties > Advanced Tab
Y. Clear settings
N. Do following
Advanced Setup:
Go to Start > Control Panel > Network Connections > Right Click on Wireless > Properties > Wireless Networks > Click on //Network Name// > Properties
Select WPA-PSK
Confirm the key
Click OK
*Note: copy and paste does not always work … type the key in manually!!! (garbage characters can exist in a copy and paste or spaces may appear!!!)
7. Mac Filtering
8. Verify Channels
If unsure:
Start > Run > MSCONFIG
Reboot the computer
on May 25, 2010 | Computers & Internet
I periodically can't get my computer to start running.
this occurs mostly due to static charges. perform the following:
1. Turn off the PC and disconnect the power supply.
2. Remove the battery from the notebook.
3. Press and hold the power button for 45 seconds.
This will discharge the static charges from the pc. Now check for the issue.
May 24, 2010 | HP Pavilion dv1000 Notebook
Startup repair fails to fix the problem
Try reinstalling windows. Insert a the windows cd into the drive and restart your computer, than follow instructions.
Dec 31, 2008 | Acer Aspire 5100 Notebook
When i try to start my computer i get the message windows failed to start and i get the two options to run startup repair or start windows normally. startup fails to fix the problem automatically. i then...
If you have the CD's that came with your notebook, there should be a recovery disk. Insert that disk and see if it solves the problem. If not, than I suggest you reinstall Windows and start from scratch.
Mac notebook
The most likely cause is a bad hard drive or a corrupted file. Start up the computer in safe mode. (Hold down the shift key while starting) that will force the macbook to run extended tests on the startup drive. If it finds any errors it may be able to correct them. If that fails use the startup disk that came with your laptop and start from it (hold down the C key during start up) that will allow you to use disc utility to try repairing your hard drive.
If the macbook fails to boot to the DVD or into safe mode. Try reseating the RAM chips. Hope some of that helps.
Aug 06, 2008 | Apple MacBook PC Notebook
Dell Inspiron 6000 PC Notebook
This sounds like the hard drive is failing. At this point you will need to run a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive and install a new operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need to be replaced.
Aug 02, 2008 | Dell Inspiron 6000 Notebook
Acer Aspire 5630 PC Notebook Problem
This could be an issue with your OS, you will probably need to boot from windows cd or start in safe mode.
May 18, 2008 | Acer Aspire 5630 Notebook
Media test fail
It seems that your Hard Disk is about to crash. If it is under warranty go to the authorised srvice center.
Jan 13, 2008 | Computers & Internet
Computers & Internet Logo
15 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
