Question about Linksys Wireless-G WRT54G Router
Linksys router wrt54g
I cant ask customer service at linksys because they will charge me but i wanted to know a few things how do i config my router so i dont time out
on online games like counterstrike source
and how do i hardwire my computer up to my linksys router i tried pluging in a cat 5 cable to the router and to my computer but it doesn't work my computer doesnt sence anything when i plug the cable thats coming in directley from the satalite dish
  • Aris C.
    Aris C. May 11, 2010
    may i know who is your internet service provider? and how to you normally connect to the internet before you purchased the router?
  • david May 11, 2010
    I am no longer active on this site. I hope someone else here can assist you.
    Novelist:
    Scholar:
  • 96 Answers
To connect your computer to the router, all you should need to do is to connect the cables in one of the numbered ports on the router and then reboot your computer so that it pulls an IP address from the router.
Satelite Internet service vareis greatly from the normal setup required of cable or DSL providers, so perhaps you should contact your internet providers support technicians as those calls are free.
As for the gaming ports; in the menu of your router, you will find the port forwarding option available. Simply enter the ports you use to play those games with and you will be able to open them up for better game playing. Test it a few times to make sure you have the settings right, but it is normally fairly simple and understandable even if you haven't read the manual before.
Posted on Jul 13, 2008
Can I load a backup config from my Linksys WRT54G to my new Linksys E1500
Have you tried doing so? Most likely presets from one device will not work on another. You can try though, it should not cause any problems. Worst case you just perform a factory reset on your router if the configuration gets messed up by trying to load the preset from your WRT54G.
Oct 14, 2013 | Linksys Wireless-G WRT54G Router
I have a linksys wireless-g wrt54g v8 router but do not have the installation cd. I have a desk top pc w/ a dsl modem and want to install the router so I can use a laptop in other parts of the house. Do...
Hi leftella, First of all, I would like to ask you few questions. 1.Who is your ISP(Internet service provider) like verizon, Bell, Comcast? 2.How many ports you see at the back of the Modem?like WAN, Ethernet, LAN, DSL, Data? 3.How many ports you see at the back of the Router?like Internet,Ethernet,WAN, LAN? 4.What is the make and model of the laptop with which you want to go wireless?
To setup the router you don't need any CD, just need to connect the Modem to router and router to your computer with hard wire Initially and then after setup, you can go wireless.
Sep 15, 2011 | Linksys Wireless-G WRT54G Router
I have a Linksys router WRT54G.... I havent used it for a few months. I called Linksys to see if they can update the firmware they told me it will need a firmware upgrade and they wanted to charge me to...
Hi Friend, As you need to upgrade the firmware for the router. Please follow the below link that will take you to the router's drivers page.
http://www.linksysbycisco.com/APAC/en/support/WRT54G/download
Please select the appropriate version from the list of the versions and as soon as you will select the version on the left hand corner slightly below the version number you will find the "firmware for your router"
Please let me know if it was of some help?
Thank you.
Jan 07, 2011 | Linksys Wireless-G WRT54G Router
Computer says it is not connected (this is a second computer that is linked to primary computer with Linksys G24ghz router. It asks for a password I do not have.
If you forget your password, click on the reset button and re-config it, usually your WLAN won't work because you deleted all the config information, if you had this problem, connect it using LAN modem, and then write the router's IP usually it is 192.168.1.1 or 192.168.2.1 and then write the username: admin password: admin
Wish this was helpful.
Aug 13, 2010 | Linksys Wireless-G WRT54G Router
How do I change my wpa key on my linksys WRT54G
Here's a information page on routers and setups. http://www.comone.ca/Support/WirelessSecurity/tabid/80/Default.aspx
This is an emulator page for your router - it basically lets you walk thru the pages like a real router but it's online just to show you how it works. http://www.comone.ca/Support/WirelessSecurity/tabid/80/Default.aspx
Click the wireless tab at the top, then below click security tab, security mode click enable, then it will offer choices of the type of security, select one and the next window will ask for key information - wep is common and easy to use. Each time you select and change it, the old settings are erased.
Oct 02, 2009 | Linksys Wireless-G WRT54G Router
I cant find my linksys passcode!
look under the linksys router for the code
Jan 25, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Timeing out
Try to reduce the MTU on the router's settings. Open the setup page of the router. Launch your browser like IE or Mozilla. Type on the address bar http://192.168.1.1 and press Enter. It will prompt you for username and password. By default, there is no username. On the password field type admin and press enter. Look for MTU under the Setup tab. By default it is on Auto. Set it to Manual and change the MTU size to 1463 (default is 1500). Then click on Save Settings button on the bottom. If it saved it, turn off the router for 30 secs then power it back on. Check your gaming again. Hope this helps.
Jul 01, 2008 | Linksys Wireless-G WRT54G Router
Network key
call Linksys customer service 800-546-5797 they'll help you better.
C-Dog
Feb 11, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
78 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
