Thank you for posting your question here on Fixya.com. If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Part of your problem will be the snake has a reversing switch so it is not as simple as just wiring two line leads. I assume you have a DPDT switch for reversing it? If so line goes to the center posts/terminals, motor L1 and L2 go to one end, motor red and black to the other end, and a jumper crisscrosses from end to end allowing the reversing.
In essence, what has to happen is in one direction motor L1 and red get power from one line and motor L2 and black from the other; to reverse motor L1 and BLACK get power from one line and motor L2 and RED the other. All of this assumes you are connecting to 115VAC since that is the portion of the diagram you reference. If not, add a comment with what you are connecting to.
John
