Question about ASUS P5N32-SLI Deluxe Motherboard
Replacement Question Ok, so after some troubleshooting I came up with a problem that either my motherboard or cpu (or both) broke. Took it to a pc store to get a more thorough troubleshooting... got same answer. Since I don't have any replacements to test which of them broke, I decided to upgrade it all together. Found some CPU/Mobo bundles, with some RAM. Now my question is, if I was to replace my motherboard/cpu/psu/ram on my pc, would anything else need replacement too? Will I have to reinstall my OS or even worse, buy new OS? The motherboard I'm buying is not the same as the one that broke, though it is on the similar line (p5n-e sli). But even so, could I buy a motherboard not in the same line and it won't affect my pc? Maybe even another brand. Sorry for long message, but thanks in advanced for any answers I get.
  • 1 more comment
  • Odessos Jul 01, 2008
    Latoof:
    I use the Alienware CD. It is MS Windows XP MCE 2005 COA OS. So I believe it is OEM.
    As for Mobo, the one I had was a P5N32-SLI SE DEL with Core 2 Duo 2.13GHZ E6400 2M Cache 1066MHZ
    I'm planning to buy the P5N-E SLI Mobo with Intel Core 2 Duo E7200 - 2.53GHz, 3MB Cache, 1066MHz FSB, Wolfdale-3M, Dual-Core, Retail, Socket 775, Processor with Fan
    Thanks a lot latoof:) Just what I needed to know, though I'm feeling like just initiating a reformat, then installing xp again from scratch. Will they charge me anything for requesting a new product code if the PC fails to accept any changes?
  • Dave May 11, 2010
    You may have to reinstall the OS. but it may be possible to do a repair install. What OS are you using and is it a retail version or an OEM version?
    Sergeant:
  • 287 Answers
NB You are more likely to have sucess if your MoBo is of a similar type (same manufacturer, chipset etc)
Posted on Jul 01, 2008
  • Dave Jul 01, 2008
    The old board appears to be an nForce 4 chipset while the new is a nForce 6 chipset. this may be problematic for a repair intsall so ensure you back up your data, game saves, email etc BEFORE starting
    OEM s/w licence is linked to the system and usually replacing the MoBo constitutes an "new" system but replacing a faulty MoBo is IIRC allowed under the licence. You may need to call up and get an activation code though. I have done this sucessfully and IIRC it is an automated service anyways. Have a pen and paper handy though.
    Have a read of these links. They may be useful when trying to repair the OS
    HERE and HERE and HERE
    Note 3rd link is a clean install so skip step 1 for a repair install.
  • Dave Jul 02, 2008
    there should be NO charge to get an activation code for your software. I was not charged anything when I did this exact same thing. Just ensure that if asked you tell them that the MoBo was replaced due to failure...
Boot failure, beeps and no display
Hi.
Do this solution first in the motherboard only processor installed need no memory.then power on your PC.if your motherboard no continues beeping.that need replacement of parts specially capacitor
leakage,became big or burn parts.
See beeping code.
Beep Code:
Description of Problem:
No Beeps
Short, No power, Bad CPU/MB, Loose Peripherals
One Beep
Everything is normal and Computer POSTed fine
Two Beeps
POST/CMOS Error
One Long Beep, One Short Beep
Motherboard Problem
One Long Beep, Two Short Beeps
Video Problem
One Long Beep, Three Short Beeps
Video Problem
Three Long Beeps
Keyboard Error
Repeated Long Beeps
Memory Error
Continuous Hi-Lo Beeps
CPU Overheating
Jun 17, 2011 | Dell Motherboard For Precision 470...
I broke the heat synch fan connector when replacing the fan. My guess is that I probably will have to replace the motherboard as this connector is on the mb. My laptop is Gateway mx6448. Is there a...
if you only broke the connector for the cpu fan, why do you have to replace the motherboard? just cut the wires and solder them directly to the motherboard , if the pins have broke off, if the pins are still there then just bend them straight and put the fan plug on them
Apr 11, 2011 | Gateway Computers & Internet
Won't boot up fans just run and green light on front isn't going on instaed little yellow light is on
Remove the side panel, leave it running and carefully feel the CPU heatsink, if it is getting warm, then power is making it to the CPU. If it is cold to the touch, there is no power to the CPU. Suspect dead motherboard or CPU.
Check also that the subsidiary 4 pin CPU power cable (usually black and yellow) is plugged in firmly, this is needed to power up the CPU.
Remove all non essential peripherals including optical and hard drives, usb and sound connectors, try to reboot, if it reboots ok replace each in turn until the faulty hardware is found
Remove one ram stick at a time, replace and reboot, see if it is the ram causing the fault.
After that, we are back to the motherboard. I'd be fairly sure at this point, the board has failed, if this is the "sunshine" board, they were notorious for burning out circuit traces after a while. You COULD try a replacement CPU but my guess would be the motherboard
Jan 30, 2011 | HP Compaq Presario SR1211NX (829160534404)...
Computer shuts down when xp loads
Follow CPU FAN and the temperature of the CPU from BIOS under the PC health.Or you can change the RAM if you have a spare .Some times CPU FAN or HEATSING base broke ,so you should check the base of the CPU FAN>You can open the cpu and apply correct heatsing paste.
Follow some links
http://www.pcbuyerbeware.co.uk/BIOS.htm
Regard's
Shibuda
Jan 03, 2011 | Mach Speed X-Caliber PT800DBP Motherboard
HP Desktop 792n Intell 4 CPU fan won't come on. Overheats, shuts down. Fan checks out OK. Replacement fan won't turn on either. All works fine with external house fan blowing on CPU
Check the pins on the motherboard where you connect the CPU fan. Could be just a broken solder joint. You can connect the CPU fan to another connector for an alternate fan as a temp fix, especially if you are not adept at soldering.
Apr 18, 2010 | Computers & Internet
Powering up
Possible that the defective power supply has caused damage to the motherboard or processor. Check replacement p/s for correct operation if its ok problem is most likely the motherboard/CPU which would require replacement
Apr 24, 2009 | E-Machines eMachines Desktop PC
Dead motherboard
bad news - an overheated F500 is a really expensive paperweight. All you can really do is try and source a new motherboard and hope the CPU and RAM didn't go the way the board did...
Nov 13, 2008 | Computers & Internet
Artisan62 Update on Boot Up Issue
INTEL is a good option, usually they have 3yrs of warranty in mother boards, its ok with intel replacement.
thanks for asking
May 15, 2008 | Intel Motherboard
ASUS P5N32-SLI Deluxe Motherboard Logo
141 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
