Question about Mitsubishi WS-55807 TV
Need some info tv turns on then goes off
Hello everyone.I got this Mistubishi ws-55807 for free and they said it needed to be fixed.What the problam is the turners on for 2secs and nothing comes on the screen and then it shuts off.I wouldnt to know what could cause that.so i can get it fix,
Thanks
Dustin
  • 2 more comments
  • altshulerm Jul 09, 2008
    After I turn on TV (push power button or usinfg rremote), green light comes for 2-3 seconds and the TV turns off (power off). What should I do?
  • Big Rob20 Aug 09, 2008
    Is this issue a service call issue or can I fix this myself?
  • hockdad Dec 26, 2008
    I have a Mistubishi ws-55807, the problem is it powers on for 2 secs, nothing comes on the screen and then it shuts off. This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems and the code is 2 - 2 = Short protect (short protect monitors low voltage supplies). I checked for open fuses and F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES ARE OPEN. I have the tools to remove the fuses but I am concerned with what else might be out and how to fix that. Please can anyone help?
  • DavidA55 Jan 04, 2009
    The TV powers on for a second or so before it shuts off (front panel or remote). It was working fine the other night. Any ideas?
  • 927 Answers
Good Day,
Try these:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Posted on Aug 07, 2008
Tv wont power up?
could be buttons,unplug them and try remote, or the convergence ics are bad
http://www.shopjimmy.com/
Aug 25, 2012 | Mitsubishi WS-55807 TV
TV won"t stay on turns off in 3 seconds WS 55807
Do the self check when power light goes off.
On front of set press and hold both the menu and input buttons for 5 seconds or longer and release both buttons.
Power light will blink a error code like: 2 blinks, 2 blinks, a pause and repeat about 4 more times.
Let me know what error code you find and I will tell you what it means.
If this information told you something rate this solution as very helpful as I do this here for free.
SD TECH
Aug 28, 2010 | Mitsubishi WS-55807 TV
I turn on the tv and it shuts off after a couple seconds
if you unlpug your tv and plug back is the green ligth blinks for one minute?
let me know so i csn help you
Jul 29, 2009 | Mitsubishi WS-55807 TV
Mitsubishi 55807 power up ,green light, then turns off.
http://www.opweb.de/model.php?id=2693 is a free link to download service and user manual-- i have the same issue with my tv
Jan 23, 2009 | Mitsubishi WS-55807 TV
My mitsubishi 1080 WS-55807 has lost the picture
Unplug the set, remove all other audio/video components, go open front door, and roll it out to the curb.
Nov 24, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
WS-55807 power up problem
If you are handy with a multimeter you can check all of the pico fuses the little green 5 amp fuses. Most likley you will find one of those shorted F95A01 most likley but could be another. You will need to change this and also your convergence amps. These three parts are most likely shorted in your set. You are looking at about 250-350 from a competent repair shop.
Feb 04, 2008 | Mitsubishi WS-55807 TV
Mitsubishi ws-55807 tv
call a repair man not much else  you can do, try and unplug for a few min
Oct 17, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
185 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
