Question about JBL ESC200 Shelf System
Amplifiers esc200 no audio,but the LCD screen has power
    Problem Solver:
  • 16 Answers
Hi! The fact that the LCD has power implies that the fault is in the Power Amp-Speaker stage.
Check 1: Check that your speakers are connected to the amplifier output properly.
check 2: If connection is proper check for power on/power off blips. If blips are heard the Power amp /speaker stage is ok .
check 3: If power on/off blip is heard then you have to check the source stage i.e CD/radio etc
Check 4: if blip is not heard. Disconnect the speaker and try with another. eliminate the case of a blown speaker by testing speaker on another system.
check 5: if speaker and source are ok. Treoubleshoot the amplifier Power supply stage with the followinghttp://www.howtodothings.com/electronics/how-to-fix-the-fuse-on-your-guitar-amplifier
check 5: if the power supply to power amp stage is ok troubleshoot the power amp stage with this guidehttp://www.howtodothings.com/electronics/how-to-fix-your-guitar-amplifier
If you still face problems feel free to contact me
Posted on Dec 13, 2008
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at http://www.samsung.com/us/support/downloads/LN32B460B2D
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
to the AUDIO OUT [R-AUDIO-L]
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
Sound comes out but poorly and buttons and LCD don't work.
Possible that your microcontroller is showing fault, it could also be the front panel control sub processor.
Open and clean the inside and possible try to check for moisture or dirt, if so clean , use a drying heater and try again.
Jun 30, 2010 | JBL ESC200 Shelf System
No audio input-have done system test,diagnostics. all report no problem but still no sound
Did you try feeding the audio line input jack with an MP3 (using MP3 headphone audio out) to find out if you do get sound? The volume control panel shows on the screen when you hit the Volume up/down buttons? Otherwise you may have power amplifier failure inside the unit ot it may lose the power supply feeding the amplifier.
Feb 27, 2010 | HP W2007 LCD Monitor
I have an Olevia Syntax LT27HV LCD TV that lost sound. Do you know what board fixes this problem? The manual says maybe interface board or system board.
It depends on where you lose the sound, no sound from speakers? no audio line out?
The amplifier circuits are on the main board. You should try hooking up a powered PC speakers to the audio line out to see if you get the sound, if you do, then the power amplifiers are bad (it is a single IC Class D dual amplifiers, IC U54 on the main board)
Sep 22, 2009 | Syntax LT30HV 30 in. HD-Ready LCD...
I have a Syntax Olevia LT27HV TV that just lost sound. I see shop jimmy has parts. Any idea what board needs to be replaced?
Sep 21, 2009 | Syntax LT30HV 30 in. HD-Ready LCD...
Hook up speakers to 32 inch lcd hdtv
"Line" level audio output is available at the audio output phono jacks at the top of the rear panel, but not speaker-level output. So, you'll need an amplifier to use in conjunction with your external speakers. (An alternative would be "powered" or "amplified" speakers that have their own amplifier, but often are less satisfactory acoustically). You don't necessarily need to get a full-fledged "receiver" with multiple in's & out's... I simply used an inexpensive stereo amplifier.
Connect the "Audio L - R" jacks on the rear of the set to the "line" or "aux" inputs on your chosen amplifier and speakers. If you go into the set's Menu - Option - Output Select and set it to "Variable", the internal speakers will be disabled, and you can control the volume (and muting) of the audio sent to the amplifier, and still have "armchair" control of the volume as before... but now with better stereo!
May 16, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Connecting
please follow me:-1-bring two audio spliters(split one audio to two audios(from near radio shack).2-connect single end of both one to the right out of dvd and the other to the leftout.now you have 4 jacks.
two audio right channel.
two audio left channel.
connect one right and one left to amplifier input right and left.
connect one right and one left to lcd screen audio in.
enjoy it.
Jan 28, 2008 | Audio Players & Recorders
TDA7564
internal amplifier.. I have the same problem. When you set the volume in 0 much time, trend to happen it.
Jun 05, 2007 | Alpine TDA-7563 Cassette Player
JBL ESC200 Shelf System Logo
276 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
