LG 1918S stays in power save mode - Computers & Internet
  • Dave May 11, 2010
    Are you able to make the monitor work at all? If so what do you do? Does the PC work OK with another monitor connected? Does the monitor work on anothe PC OK?
Tested another it didn't work. I poked around inside and it goes again but this is the second time in 2 months ith hs done this I'm out of warranty in 2 weeks
Posted on Jul 01, 2008
I have an LG E2350V monitor. When I connect to my desk top PC, it starts to display the pc starting up sequence, then after 20 seconds or so goes into Power Saving mode and it wont get out of it. ...
Hi keepintouch0,
Make sure that the power save settings are not set in the OSD of the monitor , and if they are set to switch off after some time , then you need to change the settings as per your requirement.
Hope this helps ...:) Let me know in case you have any queries.
Aug 01, 2011 | LG Computers & Internet
Have lg monitor flatron e2260 . Have had for about 3 weeks. Starting today, the monitor goes black and states "d-sub power saving mode". The tower stays on. Thx
1. Check the connections and make sure they are still tight. If the monitor isn't getting data signal it can go into power saving mode. Since it was working I would check this first.
2. Look in control panel under POWER OPTIONS and make sure it's not set to turn off after so long.
3. Also check the settings for your screensaver under display settings. That too could put it into poewr saver mode.
It could be a setting on the monitor itself that somehow got changed. Check out the settings to see if anything has changed.
Apr 21, 2011 | LG Computers & Internet
L1718S won't come on
hi
my dear LCD monitor dosn't have power saving mode it's from your CPU
may be you have problem with your Display setup from your CPU
May 17, 2010 | LG Flatron L1750S 17" LCD Monitor
My monitor goes into power saving mode all the time!
Three years old will more likely to hav bad caps by now, common problem on ALL brands, see example of failed monitors due to bad caps, you need to open it up and see, http://s807.photobucket.com/home/budm/allalbums
Feb 13, 2010 | Computers & Internet
Lg flatron w1952tq goes into power saving mode on boot computer works fine on other monitor. Running Kubuntu linux.
your LG monitor is bad then if you put another monitor on the computer and your getting video. Just as a last resort, you might want to put the LG monitor on another computer and if it stays in sleep mode then you know for sure at that point, the monitor is bad.
Feb 06, 2010 | LG 22" FLATRON LCD Monitor
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
LG W1941S-PF keeps on going on to power saving mode
Press the menu botton continuasly 35 second,if not then replace the menu botton,if not then go o the menu and disable the power saving mode..
Jul 05, 2009 | Computers & Internet
Analog power saving mode?...
I have a LG flatron wide keeps saying Analog power saving mode and than powers off how do I reset this?
May 13, 2009 | LG 22" FLATRON LCD Monitor
LG L1832S Monitor not working
LG monitor shows a green light and then goes in power saving mode and a yellow light appears,
Aug 13, 2008 | LG L1915S 19" LCD Monitor
Flatron LG monitor safe mode
Your monitor goes to Power Saving Mode when the signal it is receiving is not correct. In all probability this is not a problem of the monitor itself, rather you should check the connections and the computer the monitor it's connected to. For example you could try a different RGB cable and try it in a different computer.
Apr 13, 2007 | LG Flatron L1951S 19" LCD Flat Panel...
Computers & Internet Logo
234 people viewed this question
David Payne
David Payne
