JVC KS-AX4750 Car Audio Amplifier Logo
Problem with JVC KS-AX4750 Car Audio Amplifier
JVC dual bridgeble AMP
My Amp suddenly stopped working on the left chanel.
I took it to a repair work Shop to fix it.
as per repair 2 mosfets were replaced.
the amp is now giving out put on both the chanel. but as soon as i increase the volume the left channel bass fades away and voice gets distorted only at left chanel. what could be the problem.
please help ?
Posted by avatar on Jul 01, 2008
Solutions (1)
Have the speaker checked out and if it checks good you need to take the amp back to the repair center and have them test it better. Most repair centers have a 30 day warranty on the work they perform. Make sure they know what the problem is in detail, so they know how to check it properly. But my first thought is the speaker could be faulty. You can check the speaker yourself by switching them at the amplifier. If the same speaker sounds bad you know it is the speaker that is bad. If the sound is bad from the other speaker, then the amp is bad unless it is coming from the head unit. You can also switch the RCA input jacks after that and see if the problem changes speakers, if so, the RCA output of the head unit is bad, but that is less likely.
Add Your Solution
All problems have been solved!
