Question about Conexant v.92/v.90 PCI Data/Fax Modem (MDMV92)
Conexant data fax modem
When I try to send a fax the modem calls the phone number and then starts the transmission but then fails to complete the fax.
  • Anonymous Dec 01, 2008
    My Conexant seems to dial too fast and gets an instant busy signal before all the digits are even dialed. So, I get a "line busy" message, even though receiving fax machine is not busy. Also, sometimes I get the "no dial tone" message, but when I listen in I can hear the dial tone. There has to be some way to tweak the settings so that it either dials slower or dials "louder", or maybe the dial tones are off key and the phone company doesn't always recognize them. Also, if I keep trying, like over 20 times, eventually the fax will go through. Then the next fax I send will not work again.
Preciso driver modem 56k pci v92 ami_cw
Posted on Aug 01, 2008
How do I install HSF2014 56K data fax modem?
Pls visit the link below:
Jan 20, 2013 | Conexant Systems HSF2014 56K Data Fax...
Unknown caller and no dial tone problem on voice modem!
'unknown caller when someone calls by using phone dialer' sounds as though the dialler is blocking its identity, which you can prolly do nothing about.
Could rephrase the rest of your Question at least two different way, for clarity, please?
Nov 14, 2017 | Conexant CX11252-11 Modem
Product ID 3409 Brand D-LINK Vendor Code DFM-562IS Description 56K V.92/V.90 Software-based PCI Modem
The DFM-562IS is a software modem card. It plugs into a PCI expansion bus slot of a desktop PC. It supports voice, fax and data transmission/reception. It's a high-performance CONEXANT-based modem card, and can be used to connect to the Internet, and for fax and voice communication.
Key Features
High speed External Data/Fax/Voice
Plug and Play Installation
ITU-T V.92/V.90/K56flex Auto Detect
Fax Mode up to 14400bps Transmission Rate
Technical Specifications
Data ITU-T V.90/V.92
ITU-T V.34, V.32bis, V.32, V.22bis, V.22
Bell 103 & 212A
V.44, V.42bis & MNP 5 (Data compression)
V.42bis & MNP2-4 (Error correction)
V.80 (H.324 video conferencing interface)
FAX V.17 (14400bps FAX)
V.29 (9600bps FAX)
V.27ter (4800bps FAX)
Voice With voice support via sound card application
System Requirements Requires CPU with MMX support
Operating Systems:
Windows 98,
Windows ME,
Windows 2000,
Windows NT 4.0,
Windows XP
Manufacturer D-LINK Warranty 2 Year Manufacturer's return to base Link D-LINK DFM-562IS Internal PCI 56K Voice/ Data Software Modem
May 03, 2010 | Computers & Internet
I'm getting an error mesage: ECM error on my Sharp AR-M207 fax machine. How can I fix it?
ECM (Error Correction Mode) is a feature common in most fax machines today. It helps to minimize errors while transmitting faxes over noisy phone lines.
1) Be sure you have the latest version of the drivers installed
2) Turn the fax off, then unplug for 10 minutes, turn on and try again. This should clear up anything in the printer/fax memory
3) Check if your phone line is unsually noisy when you tried to send the fax(es) that gave you the error message. If this is the case, a sucessful fax transmission will be almost impossible. You may have a faulty phone line or an improper installation. Either of these two should be fixed by your phone company. Also, most phoen companies can test your phone line (for fre) remotely to check for abnormally high noise levels.
Please, report back if you need further assistance.
My ID: alexocuello_
Mar 31, 2010 | Office Equipment & Supplies
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
No Dial tone using Symantec Winfax Pro 10 on Windows 98
Check the physical connection of the phone line to the computer make sure that it is connected to phone line symbol of the Ethernet adapter. Then make sure that the driver of the adapter is installed properly on the computer or you can try to scan the hardware first before the re-installation of the driver using the adapter.
May 26, 2009 | Conexant chipset 56K V.92 PCI Data/Fax...
Unable to fax out
usually confilcts arrise like this when 2 or more type connections are present on one comp especially if not integrated on same card together.
solution: disable nic reboot pc then send fax should go alright.
though if you have call waiting you should disable it before sending any fax.  try using WINFAX  proven technology.
Oct 13, 2007 | Genica Conexant R6793-11 56K V.92 Data/Fax...
Conexant v.92/v.90 PCI Data/Fax Modem (MDMV92) Logo
284 people viewed this question
Top Conexant Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jessi Singh
Level 1 Expert
Are you a Conexant Computer and Internet Expert? Answer questions, earn points and help others
