Question about Hunter 22451 The Brookline Brushed Nickel Ceiling Fan
Fan stopped working
We have a fan that is 2 years old and the fan motor stopped working. The light works fine.
We have pulled the chain a few times but no response.
Any suggestions?
    President:
  • 173 Answers
Sorry to give you the bad news, but the fan motor is the major component of the fan and once they go bad it is costly to just repair the motor or replace it. You would actually save more money by purchasing a brand new fan rather than try and repair the motor on the old one. It could also be a fire hazard if you try and keep running the fan because they heat up rather quickly when electrical current is applied and they do not function properly. So if you have a switch that controls the motor and lights, please make sure that the one the controls the motor is off, but can still be able to use the lights.
If you would not mind please rate my help, I would appreciate it. Thanks.
Posted on Jul 07, 2008
Fan buttons work the light. Light button does nothing. No button causes fan to operate. What's wrong?
If there are pull-chain switches on the fixture, their operation may have caused remote control to fail. Turn off power at the source, pause for a few minutes, and turn on power. Either fan or light control, or both, may work. If not, you will have to figure out which pull-chain operation makes things right again. To avoid future problems, disconnect the pull chains at the link so only the remote controls operation.
Apr 17, 2016 | Hunter 27185 Fan Speed and Light Control,...
Lights just stopped working?
Could be a faulty switch or loose wires where they are wired together.
Jun 28, 2014 | Hunter 52" Ceiling Fan With Light And...
Non responsive light or fan
Oh, that fan problem. Just for luck, remove the batteries from the remote and press all of the buttons to eliminate a stuck button as a possibility. Next, go to the source of fan power (breaker or fuse) and turn it off. Do not mess with any switches or pull chains. Turn on the fan power and try the remote. Make note of this procedure because you will have to repeat it whenever you have a power outage or you mess with the switches or pull chains trying to solve the problem
Apr 25, 2013 | Casa Vieja Probe Brushed Nickel Ceiling...
The ceiling fan do not occilate the light turn on but the other does not work propperly
mcdevito75 here, Both the fan and lights work off the wall switch, for the fan to work there is also a pull chain close to the ceiling on the fan shroud you have to pull that chain to get the fan going and 1--2 more times for various speeds. If by chance the fan is brand new, reove the blades and check for stops in the fan motor, right where the blades hook up, these are in place from the factory and have to be removed for the fan to work, they pull right out.
Jul 27, 2010 | Hunter 21871 56'' Ergonomic Brushed Nickel...
CRFATSMAN opener - Problem when closing only
It sounds like you have a loose connection. Pull the logic board and check for bad connections especially around the small transformer.
Feb 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Fan stopped working and light now only works on pull chain
there should be a remote inside of the fan that probably went bad
Sep 05, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Fan and remote not working
make sure the main switch is on ,also the chain switch on ,before using control remote!!
Dec 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Ceiling fan/light quit working with remote
Fan does not respond to remote, checked and replaced batteries in remote. No response, and unfortunately it is now well out o warranty but have the same fan in another room purchased same year 2003 which is moving along fine. Cannot find instruction book for either one. Please help. Thanks
Dec 11, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Jun 26, 2008 | Sub-Zero 632 / S
Light not working by pull chain or remote.
I would try removing the remote part. Connect the two main (light & fan) wires direct to your house main. Then if the pull chain works then you just need a new remote unit.
Feb 13, 2008 | Heritage (5BUW52NK2YQ) 52" Ceiling Fan
Hunter 22451 The Brookline Brushed Nickel Ceiling Fan Logo
197 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
