Question about Hisense TA42P40M 42 in. Plasma Television
Connecting a gvastb4 to a hslc6633bb television
Remote not working cant get menu up
Elonex xv-s telvision no remote control cant find sourse to connect playstion without it.sky box is picked up automatically when switched on. it on scart connection
37" Elonex Widescreen HD LCD Television (Black) - Aria ...
www.aria.co.uk/.../Televisions/.../37%22+ELX+Widescreen+HD+LCD+T...
Buy 37" Elonex Widescreen HD LCD Television (Black) - HDMI, 1366x768, 1200:1, 8ms Product Name: 37" LCD TV Model No: LT37V1 Main. ... 49~61KHz; FrontControls: Power, Source, Menu, Channel Up, Channel Down, Volume Up, ... Have you tried it with a HDMI connection as I can't seem to get mine to work with my ...Missing: playstion
[PDF]Operator's Manual - SunBriteTV
https://www.sunbritetv.com/media/pdf/...R/3230HD-Op-Manual.pdf
6) Do not install near any heat sources such as radiators, heat registers, stoves, ....Water-Resistant. Wireless Remote. Control. Model 3230HD. TV Installation .... If youcannot achieve that ... to both your DVD player and Composite's S-Video connector ....Connect an HDMI cable to the HDMI output of your Playstation 3.Missing: elonex
Jan 12, 2016 | Televison & Video
I cant get the menu to leave the screen. I dont know what button to push.
Hitting the menu button again will clear this off most of the time. Make sure you are using the correct remote. If it is the cable menu use the remote that came with the cable box. If it is the tv menu uses the original television remote control. This can also be taken care of with the buttons on the television itself. Should be a menu button on the side or bottom.
Apr 02, 2014 | Dynex Televison & Video
My tv will freeze on menu
Looks like there is/are jammed button/s in the remote. Try removing the batteries from the remote and using control panel of the TV.
Jul 28, 2012 | Vizio M470NV 47 in. LCD HDTV
My television is on one chanel i cant get it on menu to program it what must i do
You need to have an original remote. In this case you may purchase an RCA universal remote that contains a menu button. Next be sure you connect you TV to a signal source (cable TV, satellite etc). Then press channel search on the menu. Hope this helps! Show a few hands of support!
Nov 07, 2010 | GE Televison & Video
How to get to menu without remote
you can only get the menu without remote, if the menu button is at the front of the television but if otherwise you can can get a all in 1 remote control for to get the menu of the television .
Thanks for asking...
Jun 03, 2010 | Panasonic PV-M2089 Combo
Cant get in to the menu cause the remote controll is bad
Most models need the remote to access the menu and settings. You should be able to get a remote from www.tvrepairworld.com
Mar 31, 2010 | Televison & Video
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
Cant get Sky+ Remote to work volume on Bush LCD32TV16HD
I rang Bush help line and got more set-up codes and that worked,we can now work the volume off the sky remote.
Oct 24, 2009 | Televison & Video
Zenith h25w35dt cant unlock auto program
USE ZENITH REMOTE HOLD DOWN MENU BUTTON UNTIL THE OSD DISSAPEARS THEN HIT 9876 ENTER CHANGE P/L SETTING IN FACT. MENU
Apr 08, 2009 | Televison & Video
Lost remote were to get code for 1988 colortrack
cant get input to work to play dvd menu wont come up with universal remote
Dec 23, 2008 | RCA 27V520T 27" TV
Hisense TA42P40M 42 in. Plasma Television Logo
130 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
