I CANT' FIND THE CODE FOR MY AIWA TV-VCR - Televison & Video
I CANT RETREIVE THE PARENTAL LOCK CODE ON MY APEV TV/DVD COMBO TV.
Posted on Sep 14, 2008
Need code for RCA remote to turn off v chip
Hello
You haven't spseified here about the combinnation of your combo. Whether it is a TV/VCR, TV/DVD, etc: When post this type of problem questions specify it.
If it is a TV/VCR combo codes are: 0227 0269
OK.
Oct 20, 2011 | Aiwa VX-S205 Combo
Tip
Dish Network Combo TV/DVD Remote Codes
CODE Broksonic TV/VCR 748 Goldstar TV/VCR 747 Panasonic TV/VCR 747 Quasar TV/VCR 747 Samsung TV/VCR 738, 755 Sylvania TV/VCR 756 Zenith TV/VCR 747 Aiwa TV/DVD 751 Apex TV/DVD 757 Broksonic TV/DVD 752 Konka TV/DVD 753 Panasonic TV/DVD 734, 765 RCA TV/DVD 749 Sansui TV/DVD 754 Sylvania TV/DVD 764 Toshiba TV/DVD 750 Go Video DVD/VCR 692, 693 JVC DVD/VCR 689 RCA DVD/VCR 690 Samsung DVD/VCR 738, 667, 691 Sony DVD/VCR 768
on Jun 06, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
I forgot my aiwa digital 40 lock password , & it lock rightnow what can i do ?
Hello
Just try this method to overcome the situation.
With TV turned ON simultaneously press "Volume Down" button on the front panel of the TV set and digit "7" button on the remote control to reset the pin code and customer ID. You have to reset the pin code and customer ID after this process. This must solve your Aiwa TV problem. OK.
Feb 27, 2011 | Aiwa Televison & Video
Need to find code for Jumbo Universal Remote to use with Aiwa S2011 MTS television. Thanks for any help!
Hello
Aiwa TV is not lited on Jumbo Universal Remote codes. Anyway try out with these codes. Sometimes may help you.
Three digit codes for Aiwa TV with universal remote are:
195/ 196
Four digit codes for Aiwa TV with universal remote are:
0195 0196 0227 0269
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch OFF and switch ON your TV with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
OK
Jan 27, 2011 | Aiwa TV-S2011 20"
I lost my original remote control for my AIWA combination TV/ VCR. VX-S135 ? I bought a universal remote control but there was no code listed for an AIWA TV. Just a VCR. I need to know the code to the TV...
what's the name/make and model of the remote?
Without me knowing the type of universal remote, there is no way I can get the right code for your TV.
I look forward to your reply.
Bye for now.
Jun 24, 2010 | Aiwa Televison & Video
Setting the clock
Use an Aiwa Hifi Remote Control...Turn on the L300 (without any DVD on the player). Wait until in the TV appears "No Disc" Open the tray and put a DVD from other region (not zone 1), don't close the tray!!!. On the remote control of the Aiwa press the "Clock" button, in some remote control you must do a button combination like "Shift+9" (Is the combination to see the clock, do the combination fast), and in other model of Aiwa remote control doesn't appear the clock button, you must try with the "random" button. If you do it right, in the corner of TV where "No Disc" appears it will say "adjust complete".
Jun 15, 2008 | Sansui VRDVD4005 DVD Player/VCR
Codes list required for Gemini G610S multi remote
Try 230, 231. 232, 233, 248 for the VCR.
Try 009, 011, 019, 024, 025, 027, 028, 051, 062, 068, 107, 115, 120, 131, 132, 139, 167, 169, 171 for TV.
Sorry - cannot help with DVD.
Len
Jun 06, 2008 | Gemini 1 Device Universal Television...
Aiwa tv/vcr/dvd combo mfg. 2003
what model uni remote do you have??
Aiwa i think is now sony. so try some sony codes.
also have you tried to auto search for your code?
Apr 09, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Aiwa TV-CN143NH
Hi Kim,
Ok , just be patient , we will try to locate for you.
Thanks,
Eriez
Feb 24, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
PAL to NTSC conversion
You might need to input a code on your VCR Remote. Try looking it up on the Internet.
Jan 13, 2008 | Aiwa HV-MX100 VHS VCR
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
