Question about Compaq Computers & Internet
My laptop is of (compaq Hp). When i switch on main power button of my laptop,the lights on front side blinks for 2/3 secs,then automatically it get switched off.Nothing happen on screen.But it is charging properly.
  • Shaun Harris
    Shaun Harris May 11, 2010
    The computer gets switched off?
    On some machines when you turn on the main power, the lights do blink for a second or two and the screen seems like it's not coming on and then it starts. When you turn it on give a few minutes to come on. Some computers act like that, it takes a few minutes to boot up.
It get switched of automatically aftr that 2/3 secs.
Posted on Jul 01, 2008
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
My HP compaq nc6000 wont turn on, a orange light comes on at the front but wont power on, it doesnt have an internal battery only runs from main power supply.\r\n Please can someone tell me what the...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jun 08, 2010 | HP Compaq nc6000 Notebook
Hey. i have a compaq CQ61 notebook and am having troubles turning it on. Whilst using it casually e.g. the internet and powerpoint it just shut off. When plugged in to the power supply, the light glows on...
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure Well Check for the below link it will provide you the steps which you need to perform to isolate the cause so that we can determine which hardware of the laptop is causing this issue. You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 24, 2010 | Compaq Presario Notebook
HP Compaq 6735s battery light orange blinking
Have you tried another power cord? If you try another power cord, and it still does the same thing, then I think your laptop is having a power problem. You need to take is to a technician to fix the problem for you.
Best wishes.
Nov 28, 2009 | HP Compaq 6735s Notebook
Wireless switch still red, wireless assistant not available
Two questions:
Q1: Do any other switches/touch buttons work? If not then follow the procedure below:
1. turn off computer 2. Remove battery and power plug 3. hold down the power button for 20 secs 4. reattach battery and power plug 5. Turn on laptop. 6. All buttons will work including the wireless
Q2: Do you see the HP Wireless Assistant icon in your system tray? If not then go to start menu and search for the above.
Once you locate it open the program and check if your installed wireless device is on or turned off. In case of the latter, Turn it on from the action list. Once your device is on the touch button will work.
Sep 10, 2009 | HP Pavilion dv9000z Notebook
Hp compaq laptop no power
you 1st need to confirm that your mains adapter is working properly, does the charging light on your laptop come on when plugged in? if it does, then good.
you should be able to cancel hibernate mode by holding the power button for about 10-15 secs
hopefully this will then allow you to power up as normal,
I don't like Hibernate mode myself as I have had previous problems with it and I tend to disable my laptop from hibernating.
if the charging led does not light when you plug in your laptop the it is possible that you have a faulty Power adapter or power controller circuit.
hope this helps
Mar 24, 2009 | HP Compaq nx7300 Notebook
Compaq c500 laptop
Sounds like a similiar problem I just resolved. Try to replace the power button board and this should help...Joe
Sep 10, 2008 | HP Compaq Presario C500t Notebook
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
