Question about Sony Handycam CCD-TRV608 Camcorder
Changing audio track only
Is it possible to record on the audio portion of the tape and leave with video intact? I would like to change the soundtrack at the source (the master) and without erasing the video.
    Problem Solver:
  • 19 Answers
Not possible unless you copy it to another tape. The audio track is married to the video track in Hi-8
Posted on Dec 30, 2008
Hi, I have a sony tvr 140E. When I try to play back a tape that was recorded from another digital 8 camcorder I get blue screen. when I play back a tape recorded on my camcorder plays fine. Any...
This smacks of the same problem that the old VCR's used to have. One of you are out of sync. The tape records on a portion of the tape in a sort of straight line track. Think of it as your track is down 1/16" from the top. The other camera tracks it's video down 1/8" instead. That's why in playback it can't read it. The only cure is a realignment. Nimsgame
Feb 19, 2011 | Sony Handycam DCR-TRV460 Digital Camcorder
IS IT POSSIBLE TO PUT INDIVIDUAL TRACKS ON A CD DISC WHEN DIRECTLY RECORDING FROM A CASETTE TAPE? JOHN GIBBONS
Yes. Iif you get an audio CD recorder like a Pioneer PDR-509, HHB-30, for example, you can record from any number of sources onto a CD in as many sessions as you like until you finalize it.
Jan 10, 2011 | Audio Players & Recorders
No sound when recording
Unfortunately whilst this camera can record video it does not have a microphone to record sound.
This is a disappointing lack of features but is one reason used by Olympus to keep costs down on this model.
One solution is to use Video editing software on your computer to add a voice over or soundtrack to your video but it is not possible to record original audio with this camera.
Hope this information helps. If so please leave a vote for it. Thanks.
May 09, 2010 | Olympus FE-210 Digital Camera
How do you record without sound
There does not appear to be any provision on the camcorder menu, to mute the audio.
As an alternative, I would recommend you connect the camcorder to your computer or laptop (via firewire if possible) and transfer the footage onto your computer's hard drive.
You can then use your computer's Movie Maker application to edit the footage - here you can either remove the audio track, or overlay your new audio soundtrack.
Good luck !
"if this has helped you, please rate this solution"
Dec 03, 2009 | JVC GZ-MG330 HDD Camcorder
I have a Panasonic TV witch is a combination Video and TV set. I am having a problem with the sound on my tape playbacks. I have tried cleaning the head, changing tapes and nothing is working. There is no...
Is this a HiFi stereo vcr? When you cleaned the heads, did you only do the heads on the rotating cylinder or only the fixed tracking/audio heads between the cylinder and the pich roller?
Does a prerecorded tape ( not a self recorded from that machine play ok?
HiFi vcrs default to the audio head(s) on the tracking/audio head if the HiFi heads on the rotating cylinder are dirty or damaged.
If a prerecorded tap palys fine, then the erase head circuit has failed.
If sound is weak and warbles, worse on SLP than SP, a weak VCR power supply.
Nov 06, 2008 | Televison & Video
Older VHS tapes play 'sped up' on S-VHS
A couple of possibilities: 1. One of the machines had a audio & tracking head alignment problem. If memory serves, tracking pulses are recorded on the bottom edge of the tape, and if one machine's head is slightly off, then these pulses aren't being picked up.
2. Do both machines have 3 play/record speeds? Many machines had SP, EP, & LP. Some didn't have EP, and if your older tapes were recorded in EP, perhaps this would cause your problem.
Both of these possibilities might be way out in left field.
Perhaps you could have a friend try your old tapes in their machine- in short, narrow down the defect. Is it the older VCR and it's recordings, or is it some goofy problem on the new one.
Lastly, you might check the audio/tracking head- see if it needs cleaning. This head is just to the right of the rotating video drum assembly.
Jan 28, 2008 | JVC HR-S3901 S-VHS VCR
Recording problem on Sony SLV-R1000
The deck needs a good cleaning. Try using a brand new tape and run it on playback for 20 min or so. You could try using a cleaning tape, but many of them are abrasive. If this doesn't work, you need a deck re-alignment which will cost more than your set is worth.
Nov 13, 2007 | Sony SLV-R1000 S-VHS VCR
Flashing
One possibility is the tracking/audio head is dirty. Remove top cover of VCR, this head sits just to the right of the rotating video head. Use a cotton swab moistened with rubbing alcohol, or other video head cleaner and clean this head, especially the lower edge, as the tracking info is recorded along the lower edge of the tape (if memory serves). Another possibility is a problem with tape travel past this head. If the tape is lifting or moving up or down, even slightly as it passes this head, tracking will be lost, hence your blue screen & bad audio. This could be observed by playing a tape with the VCR cover off.
Jul 10, 2007 | Sharp VC-H982U VHS VCR
Vcr tape problem
It sounds like the tracking information is being lost for brief periods of time. Tracking is recorded at the lower edge of the tape, and if the tape is wrinkled or otherwise damaged in this area, playback will go out to lunch. A visual check of the tape would be in order. Have the heads been cleaned in these machines? This would be another area to check.... Also, there could be small differences in the tape path alignments, perhaps the control/audio head alignment is slightly different between the 2 machines.
Apr 28, 2007 | Panasonic AG-1980 S-VHS VCR
Can hear crackling or spitting sound when selecting HI-FI
The "crackling" sound you describe sounds suspiciously like mis-tracking. That is: The result of the Hi-Fi heads (which are on the rotating video headwheel or drum) not exactly following the recorded tracks. Have you tried adjusting the tracking slightly? The reason this happens is that the Hi-Fi tracks are MUCH narrower than the thinnest video track (used for 6 hours per T120 tape). Tape stretches and shrinks as it ages. Video recorders wear with normal use in such a way that the tracking changes. The problem is often worse with tapes recorded at the SLP (6 hour) speed because the servo cannot correct errors as fast when the tape is moving slowly (on some machines only). Tape quality also counts...and manufacturers change their formulations without public notice. All these things can lead to "archived" tapes being lost. Solution: Use the best quality tape you can afford, not the cheapest; record at the highest possible speed. Store the tape carefully. Never use a cheap "rewinder" because they can over-tighten the tape causing wrinkles, stretches, and other kinds of damage.
Mar 08, 2006 | Zenith VRA421 VHS VCR
Sony Handycam CCD-TRV608 Camcorder Logo
121 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
