Question about E-Machines eMachines Desktop PC
No display T5082/T5026 computer power up fans, lights, harddrive....BUT NO DISPLAY.... unplugged devices, power supply, power plugs, fans, cards, ram from motherboard, except heat sink and prosseeor......, reset cmos pin..... reconnected everything still no DISPLAY... tried some video cards.... still no DISPLAY.....
  • 3 more comments
  • ahkp Jul 02, 2008
    I will try swaping memory... The monitor is good work with another computer.... Video cable good because monitor works with annother computer... I tryed multiple video (pci) in slots, still no display...
  • ahkp Jul 03, 2008
    no beep codes
  • Jeff124 Jul 06, 2008
    I have the exact same problem. I haven't tried a video card yet because I don't want to waste the money if it turns out to be the CPU or Motherboard; I'll just scrap it and buy a laptop.
  • ahkp Jul 07, 2008
    After replacing old memory with new memory the problem was resolved..... Thanks everyone for your support......
  • Cnythia Miller May 11, 2010
    ahkp,
     Any beep codes? With speaker connected?
    Novelist:
    Scholar:
  • 141 Answers
Try swaping your memory with a known good stick of ram.
Are you sure your monitor is good? Video cables?
Try changing (if pci) slots when installing video card.
Other than these 3 things the only pretty sure thing is; sorry, mother board or cpu.
Posted on Jul 01, 2008
  • Theresa  Smith
    Theresa Smith Jul 05, 2008
    Have you tried booting up with the operating system cd?
    Try turning on pc holding down either "Delete" or F2" which ever your bios uses to get to the setup screen. If that works you may have hope.
    Let me know and good luck.
  • Theresa  Smith
    Theresa Smith Jul 06, 2008
    Did some research, it's possible that your power supply is not functioning properly or not powerful enough for all your devices. Unplug all power connections even from the mother board. Plug power connectors on mother board first and hard drive. With any luck you may just need a more powerful mother board.
Motherbord run but not dishplay
MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Apr 11, 2011 | Intel Motherboard
When I turn on my packard bell ixtreme 6052 nothing appears yet it does see computer but does not even go to bios and harddrive read light remains on and harddrive is constantly ticking like it's...
This could be lots of things (bad HD, bad Mother board, bad RAM,etc...) first you need to narrow down the possible cause, open the computer, take out every thing that can be unplugged (I MEAN EVERYTHING) RAM, PCI cards, VIDEO cards, all storages HD, CD ROM, etc... just leave the CPU and power supply plugged in, than power up the computer and listen for BEEP's if you hear a series of BEEP's this means the CPU, power supply and mother board are GOOD, than (with power OFF each time) re-install the components you taken out (ONE at a time) to see which device causes the system crash... I've seen a modem card causing a system mall function once rediculous but true...
Feb 20, 2011 | Packard Bell Computers & Internet
Won't post, no beep. No display on monitor. Tried different AGP video card, different memory. I have unplugged everything but the AGP card and hard drive. The monitor works on a different computer so...
Basically, display card, RAM and processor are the ones affecting the display. IF trying different memory and video card doesnot help. Try changing the different processor. Thanx with regards Sajan
Jan 21, 2010 | Abit IC7-MAX3 Motherboard
Emachine t5026 does not appear to have any power, when you unplug the power cable from unit the ehaust fans breifly turn on, and light on mother board flickers, other than that sign of power Tried putting...
Unplug every thing such as the CD/DVD trays, Hard Drive, take out any dial-up modems, network cards, video cards, etc. unplug even the mouse and keyboard. Try powering on agan. If the computer seems to work, then power back off and plug in one device then power on computer. Keep doing that until you find the bad device preventing the computer from turning on.
If that doesnt work then carefully remove the RAM completely then carefully replace the RAM. Now with on the Dynex power supply plugged in to the motherboard, try again. If still nothing, remove the RAM and try again. If it still does the same thing, then the motherboard is dead and needs replaced. If instead you get a series of beeps then the problem MAY be bad RAM. Try different RAM. If that doesnt help. The only thing left is taking out the CMOS battery, It is the coin shaped battery on the motherboard. Take it out and wait 20 seconds then put it back. I doubt it is the CMOS battery, but at this point it is worth a shot.
Nov 13, 2009 | E-Machines T5026 PC Desktop
I have a emachine T5082
might be a bad power switch have had trouble like this before
Sep 25, 2009 | E-Machines Emachine T5026 power supply **...
Fan running, HDD light solid, no display
I assume there are no post codes (beeps)?
Pull everything including the video card, leave only the RAM and CPU installed.
Try powering it on, You should hear a long beep, then some short ones to tell you the video card wasn't detected.
If you still don't get any post beeps, try resetting the BIOS, and re-seat your RAM.
If it still doesn't post it could be a system board mounting issue, bad system board, bad RAM, bad CPU, or bad Power Supply
Jun 24, 2009 | E-Machines T2240 PC Desktop
No output on Monitor
Hello, It depends on how you cleaned the computer. If you removed the card from the slot then it may not be reseated back into proper alignment. If it is onboard video then there may still be a bit of dirt across one of the chip contacts. The other option would be when you plugged the monitor cable back in, you may have accidently bent a pin on the plug. Make sure that all power to the computer is off for several minutes before disconecting the cable and then look at the cable end to see if one of the pins got bent. Carefully straighten it with fine needle nose pliers then carefully plug it back in. If this doesn't work then you may have created static electricity and blew out the video system. Hope this helps, RAC
Apr 13, 2009 | AMD (90613) PC Desktop
Power,but nothing on screen
refix your ram after clean dust from it. aslo reset your bios settings,remove cmos cell for 15 minutes.then check.
Jan 04, 2009 | Intel Motherboard
Emachine t5026, 3 beeps
try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
Mar 28, 2007 | E-Machines Emachine T5026 power supply **...
E-Machines eMachines Desktop PC Logo
190 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
