this problum solution is 3 type .
[1] Repaer tv sound section replace sound ic and canacting spaer
[2] Use extra amplifer or home theater system{AUX mode} canact with tv. A/Voutput pin .
[3] if you are use setup box or chenal convater then canact A/v Out{ L -R ] to AUX input . home theater or extra Amplifer system
selact any one option and enjoye....
If the previous posts didn't fix youru problem, and I doubt they did, then you most likely have a weak CRT and the video is being muted. you can sometimes tell if that's the problem by turning up the screen voltage slightly to see if the picture comes back on. If it does, then the CRT is weak. This is a very common issue with Sony CRT TVs, and can sometimes be rejuvenated by a good shop for fairly cheap.
pls .check your tv power cabel pin and plugg bitwin sparked or luss canaction [pls unplugged cabel pin and see tv. power cabel pin on top side black spot.]
pls try power cabel properly canact if loose replace with new.
NOTE:most of tv poblum is making power cabel loose. so canacting tv power cabel or power bord check with electrician
pls check your tv colour system it is not maching with your country col-sys [PAL /NTSC/SCHAM] so pls open menu and set col-sys select any one or set col-sys is AUTO see the colour pictur.
* NO colour [B&W} pictur
[1] cabel singnel is wek.Pls. check cabel canaction re set pin or cabel canaction.
[2] pls tune ch. set Auto serch or fine tune to set ch.
if not colour pictur then problum is inside of your colour tv set.
pls. check power coad is likage or luse canaction in plugh
if ok then problum is inside of tv so pls. cheked in pcb.....
1st : SMPS output voltage and 5v /12v/ 24v /135v dc filter capaciter cheked and replace 470/16v /1000/35v / 220/450v if any capaciter likage or sort * first cheked dyode.
2nd : EHT output line capasiter or dyode checked 4.7/250v /100/160v
and line coil or 1ohm register cheked
3rd : DT (driver transfermor ) and with cancting spear dry.
note: pls descanect tv with DVR and cheked tv set is turn on atlist 10min. minimum with any ather product (DVD , GAME BOX ,CABEL CANACTION) if is ok. then problum in DVB setup box .
Fax works easiest via a dial-up modem though there are programs that allow broadband facsimile transmission. Use more words and you get better answers. ~Steve
