Question about Whirlpool Washing Machines
I keep getting message on my washer F-21 what does that mean?
  • 246 Answers
F21 is a drain error code. You likely have something stuck in your pump. Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on) Once you have the panel off, the white object in the front center is your pump.
Remove the #20 torx screw out of there too to make life easier. Slide the pump forward slightly so you can raise it. Now, on the front of the pump is a handel that you will need to turn counter clockwise. So after placing something underneath to catch
the water left inside the machine ( a large bowl or bucket), turn the knob slowly counter clockwise. If there is too much water for your container, screw it back clockwise and go empty your container. Repeat until all of the water is out. Once that is done, unscrew it all of the way and slide if forward. You will usually find missing socks, toys, coins and all other kinds of fun objects. While you have the trap out, reach in with your finger to the hole on the right. Try and turn the wheel inside to make sure there isn't anything keeping it from turning (bobby pins, nails, screws, etc) If there is, you will need to unclamp both hoses on the back of the pump and remove any further forign objects. Now re-assemble the unit but leave the panel off. Run a quick fill and drain to make sure all of your connections are tight and you don't have any leaks. Put your panel back in and you're ready to go.
Posted on Jul 01, 2008
Message code F 21
Not sure what brand of washer you have. I know that the duet series has a drain filter that gets plugged occasionally. You open the drawer on the Good luck it's located above the drawer in the middle. Remove, rinse out the filter and reinstall. F21 means slow drain on many washers. It usually means, clogged filter, broken pump or impeller in the pump, or the drain hose is kinked or clogged. Good luck.
Jul 21, 2016 | Bosch Washing Machines
What does F- and 21 mean
Error code F 21 means the drain is clogged...follow this advise for the Whirlpool washer as Maytag was bought by them
there is also this site for the washers http://fixedappliance.blogspot.ca/2011/11/whirlpoolkenmoremaytag-more-f02f21-sd.html
Jun 04, 2015 | Maytag EPIC MFW9700S Front Load Washer
Getting an error message on my Whirlpool duet washer - F21
F 21 means slow drain remove lower kick plate couples screws at bottom//you will see the drain pump there is a clean out at the front of pump/ turn that out counter clock wise that is a coin collector but many other objects get in it to/ remove items and reverse to put unit back together....
If I helped you please vote If you need more help please ask good luck
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
A message F-21 keeps flashing on the screen
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it.
Hope this helps... Please post back if you need more information.
Daniel
Jan 13, 2011 | Kenmore HE2 Plus Front Load Washer
I cant update the version to 3.00 keep getting error messages with everything i try, USB, INTERENET, NOTHING WORKS!!!
ok well remember the population of the world is 7 billion+ and 21% of the world has ps3's or xbox 360 or wii's. they keep updating so remember its not just you trying to get an update. by all means keep on trying
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
MY CABRIO SAYS SD ON THE DISPLAY
That means that the machine is sensing excessive suds. I just got the same message on my Duet today. The problem with mine, however, is that there is an issue with drainage. We emptied the drain filter and are currently trying to get it to work properly. It switched from Sd to F-21 and has repeated F-21 5 times until just now when it continued on in the drain/spin cycle to actually spin the clothes. Will keep you posted...
Aug 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite Washing machine error codes
I am getting F35 error code. What is the problem?
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
F-21
replace the contol board
Apr 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal De
