Question about Cameras
The monitor on my Nikon D50 will show the menu and other computer instructions, but no images through the lens, and I can't press the shutter all the way down. The shutter seems stuck, but turning the camera off will not solve the problem, nor will charging the battery (Tried both) Can't afford a new camera. Help!
  • 3 more comments
  • Jennifer Popky Jul 01, 2008
    It is still stuck whatever mode (A, S, P, M) or in Auto or Manual focus. I even switched lenses and saw the interior of the camera looking deceptively normal! I fear the worst.
    I just added the comment that I have adjusted the mode, changed the AF, looked at the ics on the memory card. If the mirror is jammed up because of a fall and blocking it that could explain it. I don't remember that- I remember a screen detailing info of every shot I tried to make- I could not get rid of it. Then this.
    Thank you all for your wonderful suggestions!!! I have to go to sleep right now ( Took out the battery again- will have a go at the clock battery in about 3 hours) Good night, good morning, if you need Mac help, tell me where to sign up. (Been fixing them since they were still Apple IIs- then again, I can still fix a film camera. God I'm old)
    What switch and CCD? (No sleep no handy dandy guidebook makes me a wee bit cranky, Sorry. Also a wee bit slow)
    No Warranty- it would be too old anyway (A year!) If Nikon has to fix it, it would cost me so much to have it "analyzed" and then fixed I could put my money towards a newer model- which would be heresy if I were talking about my Nikon F camera. The shutter, upon inspection, is not stuck. I'm really not trying to be difficult- I know I sound petulant as all get out. I'm just frustrated
    Sergeant:
    Champion:
  • 230 Answers
This problem is due to the stuck of shutter ,so better you give it to service if you have warranty ,then go for it .Because repairing by own may void warranty
Posted on Jul 01, 2008
    Guru:
  • 1,894 Answers
This can be sorted out two any one of the following two problems.
either the the switch is bad
else the CCD is bad.
  • dewan nafees ahmed Jul 01, 2008
    i can say that 80% of your problem is due to the shutter switch which is stuck.
    even we can confirm it 100%
    i can say that YOU CAN GET IT FIXED BY JUST CHANGING THE SHUTTER SWITCH.
    and please get it done by a authorized service center.
    the shutter switch sir.
    i think the problem lies only with the shutter switch.
    but i warn you one thing;
    replacing the shutter switch is not a easy job to be done.
    it involves very delicate handling
    camera parts are very delicate to handle.
    so be careful if are attempting to do it by yourself.
    but i am not responsible if you mess it up.
    mu advice would be to take it to Nikon authorized service center and get it done easily.
    as per my idea the switch wont cost above 50$ and the service charge will differ from place to place.
    thank you for your cooperation.
    good luck sir.
  • 75 Answers
Can u tell me ur model number?
  • 1 more comment
  • adamya s Jul 01, 2008
    hey, tell me ur model number please,fast....
    To reset the Camera, please remove the batteries from the Camera and then press the power button for 15 seconds.
    Then, reinsert the batteries after 1 minute and check if that helps.
    Also, I suggest that you try "Initialize" the Camera using the initialize option after resetting.
    You'll find the "Initialize" Option under the Main Settings 1 menu of the Camera
    Master:
  • 497 Answers
It could be a connection problem. Try cleaning your lens contacts (on the camera mount and on the lens) to make sure it's not just a bit of oxidation on the contacts causing a bad connection. A t-shirt with a touch of alcohol would probably do it.
I'd do the same thing with the battery contacts (and try a different battery if you have one, in case the battery has a problem).
Have you got another memory card? If so, I'd try a different one to make sure it's not shorting out the camera somewhere. I'd make sure to format it via the camera menus for format, too.
  • 1 more comment
  • Yaz  S
    Yaz S Jul 01, 2008
    http://www.sp-ts.com/
    this is a gud place for u to take ur camera if u had bought thru internet or run out on warranty.
    and btw do u get any error message on your monitor??
    please do keep us updated for further assistance.
  • Yaz  S
    Yaz S Jul 01, 2008
    Gud night sir!! Happy dreaming! ;)
    Thank you for using Fixya
  • Yaz  S
    Yaz S Jul 01, 2008
    i absolutly agree with Worldvet!!
    Master:
  • 382 Answers
please try to remove your batteries and memory card..then try to close the shutter..may be it can help you..this a common problem occuring in nikon d50 after 150 photos or so..so just give a try because there might be a contradiction due to battery..thank you!!..
    Guru:
  • 859 Answers
What mode is your mode dial in right now and do you have an unlocked memory card installed?
  • 2 more comments
  • Glenn Rogers
    Glenn Rogers Jul 01, 2008
    What type of memory card are you using?
  • Glenn Rogers
    Previously then you were in a detail preview mode. Do this.
    Remove all the batteries including those that may be accessed from the
    bottom of the camera and are button batteries. Leave these batteries
    out overnight and reload them tomorrow.
    This is called a hard reset and may do the trick. Otherwise, post one way or another.
  • Glenn Rogers
    Sorry, you will have to deal with some pretty off the wall answers, even though Sweet Rascal is good. I'm sure he's just as tired as you, so give him a chance.
    But, if the hard reset doesn't do the trick you'll have to find a camera clinic and have them go through and tend to all the linkage and electronics. There are some problems that can't, by their nature, be properly diagnosed via email.
    Regards,
    Worldvet
  • Glenn Rogers
    You are by far not even close to being petulant. You should see some of the comments made to us.
    If leaving all the batteries out and reinstalling them didn't resolve your issue it is then electromechanical or electrical alone.
    THIS IS A METHOD OF LAST RESORT AND NOT FOR THE FAINT OF HEART. DO THIS AT YOUR OWN RISK. One of the things I'd say is to carefully tap it around the body to see if a mechanical link will dislodge itself. DO THIS AT YOUR OWN RISK
    As stated thisi is a last resort DO THIS AT YOUR OWN RISK.
Can my Nikon D50 be fixed or do I need to send it for repair?
This happens during malfunction of mirror and shutter.that is when cliked shutter opens but mirror did not go up so blank monitor screen hence no image in card. Take to skilled technician to replace shutter loader mechanism.
Apr 25, 2016 | Nikon D50 Digital Camera
How to change the color mode on nikon d50
here is where to find the settings
press MENU button
select Shooting Menu (camera icon)
select Optimize Image
select Custom
the color mode is here. mode 1 is standard RGB
mode 11 is Adobe RGB
mode 111 is for custom color settings, it allows you to increase/decrease a number of settings relative to color.
once you make a change be sure to press the "done" button or your changes will be lost...
Jan 12, 2011 | Nikon D50 Digital Camera with 18-55mm Lens
Hi i have dropped my d50 and err comes up
There is a motor/gear assembly inside the camera that moves the lens in and out and covers the lens when it is retracted. When it dropped, you most likely cracked or shifted something out of place. A broken tooth does not stop function, but shudders when it hits the gap. A shifted gear, slips and similarly may cause this effect. If it doesn't open the shudder, you get no picture.
You will need to open it up and attempt to repair the mechanics that drive the lens.
May 05, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon d50 monitor does not work during photo shooting, must use view finder
This is completely normal. The monitor is used for setting menu items, displaying shooting info, and reviewing images. Like SLR have functioned for over fifty years, you take pictures by composing and framing through the viewfinder. Only the most recent dSLRs have the Live View capability which allows you to use the monitor like a point&shoot camera.
Apr 05, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Dropped Nikon Camera Sadness
Hi Al
not sure if i can help here but will try.
Ive not owned the D50 but i have the feeling the highlights function is similar to other cameras in the Nikon range.
On your cursor when viewing an image, just press down on the cursor maybe once or twice to remove the highlights .This is just a pointer for you like the histogram.
Now it seems like you may have damaged the sensor and will not collect enough light.
Try setting the camera to A = aperture priority and take a shot in bright light...no flash.
Are the images still dark ?
If so raise your iso to 800 and shutter speed to 1/250 at F5.6 aperture in mode S =shutter priority and take the shot in bright conditions.
Are the shots still dark ?
Nov 11, 2009 | Nikon D50 Digital Camera
My Nikon D50 locks up intermittently
you like to try and swapping batteries.. i guess it couldnt supply enought power to the shutter motor.
Aug 13, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Does Not Autofocus
replace the lithium battery 1.5X2 . then press then ok good, but does not work the drive motor was broken.
Nov 05, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Shutter
I had the same problem but replaced the lens with a different lens and it worked just fine.
Aug 27, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Won't take pictures
The flashing F-- is addressed on page 123 of your users manual. My camera was also doing that and it was very frustrating. The lens is not being read by the camera. Try cleaning the contacts in the lens and camera body. In my case I had dropped my camera from a very short distance, but it was enough to make the lens not seat right in the body. Have to buy a new lens. Go to a camera shop and switch out the lens and see if it works...mine did. Problem solved.
May 29, 2007 | Nikon D50 Digital Camera
Cameras Logo
51 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
