Question about HP 48gx Calculator
ON switch The ON and zero switches of my HP48GX don't work!. Sometimes appear a number zero in the screen, but it is impossible having it when necessary. Thanks a lot
  • fabianromano Jul 11, 2008
    That is because the contact between the keyboard and the circuit is dirty or there is no enough pressure. Try pressing right below the screen (were the contact is) and press the key. If it works while pressing the front of the calculator below the screen then that's your problem. I had the same problem. When I figured it out I was so excited that I opened the calculator and out it together to fast that I broke something else, can't fix it. be careful
  • HP Master
  • 7,993 Answers
.The selft tests will show you what is wrong, and if the calculator requires repairs.
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.
Hope it helps.
Posted on Nov 07, 2009
  • k24674 Nov 08, 2009
    If calculator requires repairs,
    There is an HP customer self repair (CSR) which you can
    contact. On the site it is said that the service is available for
    products under warranty or on contract. but you have nothing to lose by
    contacting them. Here is the link to the web site.
    - You can also try this site. They do repairs on most models, except the newer ones.
Can I get my matric result here becouse I was a party time student?
It appears you had a little too much "party time," as you are on the wrong site for academic results
Jan 08, 2017 | Office Equipment & Supplies
Is there an inexpensive manual avail for TDC Vivid Mainliner 300 slide proj.?
I see manuals on eBay for around $14 but nothing cheap or free. It's unfortunately one of those that is just rare enough that nobody wants to cut anything lose. Sorry... You might try a Google search if you are having a specific problem - sometimes you can find a support or community forum that has a thread about the issue.
Good luck
Nov 20, 2014 | Office Equipment & Supplies
Im looking for the total combination for this nuber 13 20 31 36 41 45 permutations i think its called
Do you want combinations or permutations? They're different things. A combination of n items taken m at a time, sometimes written "nCm", selects m items from a group of n without regard to order. A permutation of n items taken m at a time, sometimes written "nPm", selects m items from a group of m with regard to order.
Given six numbers, there are six combinations of one number, 15 combinations of two numbers, 20 combinations of three numbers, 15 combinations of four numbers, six combinations of five numbers, and one combination of six numbers.
Given six numbers, there are six permutations of one number, 30 permutations of two numbers, 120 permutations of three numbers, 360 permutations of four numbers, 720 permutations of five numbers, and 720 permutations of six numbers.
Oct 22, 2014 | Office Equipment & Supplies
Riddles with answer
Like, -300c near absolute zero. You\'re talking a space walk here.
Apr 09, 2014 | Office Equipment & Supplies
What are rational numbers
Use the words: decimal part, not decimal fractin
Any number whose decimal part is periodic (has a recurring pattern that repeats indefinitely) is equivalent to a rational number, IS a rational number
0.345 345 345 ... =345/999=115/333
In the following screen captures, discard the last digit if it does not belong to a period. It is the effect of rounding up of the calculator
Period is 345
Period is 1
Period is 09
Period is 79
In general, if you have a decimal part of the form 0.d_1 d_2 d_3....d_n d_1 d_2 d_3 ...d_n ... where d_1 is the first digit of the period, d_2 is the 2nd digit of the period, ..., d_n is the n-th digit (and the last one) of the period, then the fraction representation of
0.d_1d_2...d_n d_1d_2... d_n ...=(d_1d_2...d_n)/(99...9) where the number of 9's in the denominator is equal to the number of digits in the period.
Once the fraction is found, one should reduce it to its simplest form.
Mar 02, 2014 | Office Equipment & Supplies
What are the first 6 triangle numbers
0, 1, 3, 6, 10, and 15. If you don't consider 0 to a triangular number then the next one is 21.
Oct 01, 2013 | Office Equipment & Supplies
HP 48gx Calculator Logo
139 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
