Question about HP Compaq iPAQ MP4800 Multimedia Projector
Compaq Microportable Projector MP4800 will not light up
 Hello, here is the problem with my Compaq Microportable Projector MP4800
This is what happens: 1. Plug projector into power outlet
2. Turn on the power switch
3. The Standby button light up and is white in color
4. Press the Standby button and it turns green in color
5. There is a clock like noise.. Tic Tic Tic for 20 seconds
6 Then the "ticking" stops and the fan comes on for 40 seconds
7 no projection No light in the lamp
8. Then the projector turns off
9. The Standby button light up and is white in color
troubleshooting : I have looked at the HP Trouble shooting ideas and they do not help
setting changes : Yes we have placed a new projector bulb in the projector
  • 1 more comment
  • pjenewein Sep 15, 2008
    I have the same problem with my MP4800. I have also replaced ther bulb and can not find any help on Compaq/HP website. Anyone have any Idea's?
  • Anonymous Oct 15, 2008
    i had the exact same problem and figured it was broken so i took it apart to learn something. what it has inside is a color wheel (made by young optics inc.) and mine was broken (broken glass) which wouldn't allow it to spin to start up. so i am guessing that it automatically sends it back to standby so as not to burn up anything. but hey i am just an amateur.
  • Ossie007 Nov 11, 2008
    I have the sam trouble with my projector! A ticking sound and no light. This seems to be a common problem with it, so I guess Compaq knows about it?
SOURCE: no power on Compaq MP2800 Microportable Projector
I am currently struggling with this issue.
There is an easily-accessed fuse inside the projector.
I was very excited to discover this last night.
However, before you get you're hopes up (as I did) remember: If the fuse blew, something else probably went first. After buying and replacing the fuse today, I realise that I need to replace or repair the power supply as it pops the fuse every time.
Here's how to get to the fuse:
Take off the lamp.
Now, looking at the projector from the back, you need to remove the left hand side panel.
This involves taking out 2 screws from that panel, 2 from the bottom and the 2 video connector hexagonal bolt things that are also in that panel.
The panel sort of hinges off, starting from the bottom.
You will see the fuse in the bottom right corner where the power lead goes.
It is a slow-blow (time delay fuse) so get the exact same one to replace it. A pack of 10 cost me €4.19 in Maplin, Galway, Ireland.
Anyways, this did not do the job for me... the power supply set the fuses off like fireworks and also blew a few in the socket plug as well (I don't think US readers will have those)
I will let you know how I get on with the power unit....
Good luck to ye!
Posted on Jan 30, 2008
  • 563 Answers
SOURCE: HP vp 6120 Projector
Hi there
Have you reset the lamp timer ?
If you have and the problem stil occurs you will have to replace the Ballast ( lamp's powersupply ) This is a very common problem with this specific HP model.
Posted on Mar 26, 2008
SOURCE: Compaq iPAQ Microportable Projector MP1200
you will not be able to find these parts
Good luck
buy a new projector
Posted on May 14, 2008
SOURCE: Unit turns on for 20-30 seconds then powers off.....Please Help
it is the ballast issue,u can try one of the equivalent ones or just try & rework on the old one, perhaps one of the mosfets is leaky!!!!!!!!
Posted on Feb 08, 2009
  • 2237 Answers
SOURCE: no display from projector
try resetting the lamp timer. if that doesn't work: listen for a high pitched whir when you power it on. if you don't hear it, the colorwheel needs replacing. if you do hear it and it doesn't light, the ballast is bad and needs replacing.
Posted on Aug 10, 2009
it might be a problem with overheating, have you ever cleaned the projector? there might be alot of dust blocking the airflow.
If that doesnt help let me know.
Apr 15, 2008 | Compaq MP2800 Microportable Projector sps...
Compaq MP2800 DLP Projector
If the projector is not getting a source it might go on standby maybe check where you plug it in.
Projectors require quite a bit of power and should be on a single loop/outlet not hooked up to a powerbar with more things on it.
Hope that helped.
Dec 26, 2007 | Compaq MP2800 Microportable Projector sps...
Need ac adapter for Compaq projector
Hi Tech Lady , greetings !!
Your projector has a "Multimedia Adapter" .
You can purchase the adapter from or directly from HP.
Trademoon is a discount supplier of new and refurbished Compaq and HP parts.You can call them at 97
2-682-5000 or log on to
Or you can also call HP/Compaq at 1-800-474-6836 and say "SPAREs"
The specifications of your adapter is :
Power Consumption 5 Watts (standby)/185 Watts (full power)
Power supply 90V to 255V (auto switching): warm restrike after 45 seconds
Goodluck :)
Jun 04, 2008 | Compaq AC Adapter Projector Lamp
Compaq projector
Hi gambill32
If the VGA is a output you could get a converter that takes VGA to Component ( RGB ) and hook up the 3 x component RCA's to the TV 's component in.
This converter can be found at most good PC and AV shops.
Good luck and thanks for using Fixya.
P.S. If you need any further guidance , just send me a request.
May 12, 2008 | Compaq Microportable 1400 Multimedia...
Compaq MP 2800
Hi there
Does your Projector support Windows Vista ?
Mar 07, 2008 | Compaq 207685-001 - Microportable...
Good luck
buy a new projector
Jan 16, 2008 | Compaq iPAQ MP1200 Multimedia Projector
Compaq MP 2800
Have you tried cleaning ther bulb housing and fan area with a soft brush and vacuum?
X2 infocus projector
make sure u have the lid back on or wont come on for the lamp
Nov 11, 2007 | Compaq MP2800 Microportable Projector sps...
Compaq MP 2800 Micropotable Projector
I had the same problem!  The problem is dust on the color wheel.  At side of the color wheel is a wire connector attached wit one small screw,  with a cottom tip clean the small lens  and surface, that's all. Put the connector and screw  and it will OK!!
Oct 10, 2007 | Compaq MP2800 Microportable Projector sps...
HP Compaq iPAQ MP4800 Multimedia Projector Logo
228 people viewed this question
Ben Johnson
