Question about ViewSonic VA720 17" LCD Flat Panel Monitor
HP vf51 monitor ac power cord
Thank you for you help and quick response!!! This site is great. I did go to e-bay and found what I needed!!
God bless!!
mrsbly
  • 405 Answers
You are very welcome, I was glad to help and am glad you got what you needed. Thanks for using Fixya and I wish you the best of luck.
Posted on Jul 01, 2008
Desktop will not start no response to power on button
1) you must open the desktop and look for any connector loose
2) test the power cord for open or replace
2a) Test the power button for open or defective
3) see if the switch behind is 110 or 220vca adjust it
4) Test the power supply and see if the fan are working, test the output for +5VDC, otherwise is faulty.
God bless you
Jun 19, 2012 | HP Pavilion m7650n (RF254AA) PC Desktop
I need a power cord for the HP 5590 scanner
Hello alex951,
Welcome, and thank you for using FixYa!
I found a great listing for this power supply you require, on eBay!
Of course it is always wise to use "Top Rated" sellers there.
Here you go!
Power Supply
http://www.ebay.com/itm/24V-AC-Adapter-Power-Supply-HP-ScanJet-5530-5590-5590P-/300566844523?pt=LH_DefaultDomain_0&hash=item45fb2e146b
Happy scanning!
Sep 06, 2011 | HP Scanjet 5590 Flatbed Scanner
Hp compaq nx7400 - battery died and power cord will not turn comp
Some laptops will not power up with a completely discharged or faulty battery. Remove the battery from the laptop, plug in the power cord and try to boot the system. If the system boots, your battery needs to be replaced. Replace your battery as soon as you can, it's not a good idea to run the laptop for extended periods with an open battery bay.
May 07, 2009 | HP Compaq Presario V2000 Notebook
Ref:hp pavilion f 1503 power supply
HP / COMPAQ
PAVILION 1503 D5061-A F1044A F1044B F1503 1703 F1703 VF51 VF52 L1800 0950-3415 ADPC12416BB ADPC12350BB
Input: 110-240V 50/60Hz Auto-Detect International Compatible Output: 12V DC, up to 5A / 60W max (Great upgarde for lower wattage)
Connector: Barrel, Center +
Dec 14, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Need a replacement AC adapter for my Mintek Digital Portable DVD Model: MDP-1030. I have discovered that the Mintek company is no longer is business???? I have called the phone number in my paperwork, and...
I found some used, as is/parts, players with all accessories included, on E-bay. As I only need the AC/DC adaptor, I am elated that I did a search on E-bay.
Thanks!
Jul 02, 2008 | Mintek MDP-1030 Portable DVD Player
Ac power cord for HP vf51 flat panel monitor
Good Day Tricia,
I had to pull up you owner's manual to get the spec's on your cord, so if you need the manual follow this link:
http://h10032.www1.hp.com/ctg/Manual/bph08231.pdf
Anyway after reading the spec's you need an AC-DC power supply that outputs 12volts at 3.3amps. What makes this difficult to find is the 3.3amps, most aftermarket power supply only go up to 2amps. So what's next? Well you can order directly through HP at this link:
http://partsurfer.hp.com/cgi-bin/spi/main?sel_flg=partlist&model=P4824A&HP_model=&modname=HP+vf51+15-inch+LCD+flat+panel+display&template=main&plist_sval=Power+Cord&plist_styp=subcat&dealer_id=&callingsite=&strsrch=&keysel=Power+Cord&catsel=%3F
If you do this make sure get part 8121-0740 if you live in the states, or part 8121-0731 if you live in europe.
The only other suggestion I can give is to bring the monitor into a radioshack and see if they have a 12VDC 3.3AMP (you can get a universal with higher amperage if needed, the monitor will only draw the 3.3 it needs even if it is supplied more) and the reason I say bring it in is so they can match the size of the plug that goes into the monitor, as there are about 20 diffrent diameters's. Again the problem you may have is finding one with a high enouge amperage.
I hope this helps
Good Luck
Jul 01, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
KDS RAD-5 monitor set up
THE POWER SUPPLY PLUGS INTO A WIRE STICKING OUT OF THE END THAT PLUGS INTO THE COMPUTER
Apr 15, 2008 | KDS RAD-5GS 15" Flat Panel LCD Monitor
Hooking up a HP L1755 17
What is the way to get the very best picture quality when hooking up my new HP L 1755 Flat Screen Monitor to my E-Machine W3052 which is about 3 years old.First would it be compatible or the best idea to hook up VGA to VGA.DVI to DVI which means buying a new Video card for my Computer so the DVI could be hooked up to my computer, or hook up the DVI to VGA Connector ? Would a DVI Video card be worth the extra costs if I went that route ?This HP L 1755 only has a response time of 25 ms, is that good enough to watch Music Videos or not ? I do not do any gaming.Can you tell me the best detailed step by step way to hook up this monitor to my E-Machine W3052 Computer and which Connector to use ? If I need a DVI Card what would be the Part number or Card I would need to get ? Sorry about all the questions.Any guidance and input would be greatly appreciated since I have a disability and need some help and to be honest I do not have 50.00 for a DVI Video card. Sincerely & God Bless ! Thanks,Diehard16
Feb 18, 2008 | Computers & Internet
Hp pavilion vf51
It is the inverter board that is causing the screen to be feint. But is was the video resoloution being set too high that made it give the "out of range" message.
It's not easy to get anywhere to repair LCD monitors, and the prices could be well out of scope to bother with the repair.
Having said that, you can now call a few TV repair centres close to you and ask for a quote based on repairing the inverter circuit.
Hope that helps =)
Aug 17, 2006 | HP Pavilion VF51 15 in. Flat Panel LCD...
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
55 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
