Question about Lands Phones
Set up plantronics 520/521 to your cell phone
  • robgersten Jul 19, 2008
    Why does my plantronics 520 blue-tooth headset constantly connect and disconnect?
No it will not turn green it will had no color
Posted on Sep 20, 2008
I received, what the seller says is a "new" 520/521 bluetooth, bulk packaged, so there was no manual. My first bluetooth, so a little confused. I first plugged in the charger and there is a red light that is on. My question is, will that turn green when fully charged? Any thing else a rookie bluetooth first timer should know. Thanks.
Marty
Posted on Aug 25, 2008
Plantronics edge
Hello
If the headset is connected to phone or PC. On your phone you have battery saving option because that turns off WIFI, Bluetooth and screen when not in use faster. Check your phone settings.
Apr 10, 2014 | Plantronics Cell Phones
How to setting plantronics discovery 975
Plantronics Discovery 975 settings:
Not sure exactly what you are specifically asking, however here is a link for the 975 user guide. The 975 user guide will tell you all about the settings and how to put it into pairing mode to connect to your cell phone as well.
http://www.headsetsdirect.com/pdf/discovery975_user_guide_en.pdf
Good luck from Headsets Direct - 800-914-7996.
Aug 19, 2011 | Plantronics Discovery 975 (8164001 P)...
Need to pair my nokia5310 to plantronics explorer 210
You don't mention if this is your first time pairing the headset, you will need to turn on your blue tooth on your cell phone, the light on the headset should come on flashing red/blue. If it does not refer to sub pairing instructions below. The cell phone should find the headset. 2XX Plantronics in your list. If the pass key is needed it is (four zeros). Second time pairing or more than one device, turn on bluetooth feature, headset turned on, press and hold the call button for about 5-6 seconds. Release button and set headset aside. On cell phone hit bluetooth menu, search for add device. The cell phone should find the headset.
Aug 17, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Voager pro plantronics how to use with my cell phone set up connection
The pairing instructions are found in the link below for the Plantronics Voyager Pro+. Follow them closely, and you phone's pairing instructions, and you're good to go.
Plantronics Voyager Pro+ User's Guide
Good luck from Headsets Direct!
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
How to connect the plantronics explorer 233 ?
  • Make sure your Plantronics Explorer headset is fully charged and turned off.
  • Press and hold the call control button (the button on the face of the headset opposite the earbud) for six seconds. When the light begins flashing blue and red, the headset is now ready for pairing with your phone.
    Select the Menu on your cell phone. Once the menu is displayed, select Settings, then Bluetooth Menu.
  • Select the option to add a new device. This will both turn on Bluetooth capabilities in your phone and put it into a setting known as "Discovery mode." The phone should discover your Plantronics headset automatically and display "XXXPlantronics." ("XXX" represents the model series number, such as "320Plantronics.")
  • Select the Plantronics option on your phone. In many cases, the phone will automatically recognize the headset, but if you are prompted to enter a passkey, proceed to the next step.
  • Enter "0000" if you are prompted for a passkey. Your headset will flash blue once it is successfully paired with your phone. Once paired, the Bluetooth headset will automatically recognize your cell phone each time it is turned on
  • Feb 01, 2011 | Nokia E63 Cell Phone
    Cant set to my phone
    Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
    Plantronics Voyager Pro Pairing Instructions
    Dec 13, 2010 | Plantronics Voyager PRO Bluetooth Headset
    I have a samsung SHP-M800 and i am trying to set my bluetooth (plantronics explorer 233)?????????????????????????
    Hello my friend.First you must turn the bluetooth feature on your phone to on and find a setting invincible/discoverable/seen by other devices and turn it on too.Next, hold the call button on your bluetooth until the light begins flashing blue and red, this means it it in paring mode.Then find the plantronics device in your phone(scan for bluetooth devices). Select your bluetooth headset and enter the password (0000) when it asks it.
    Feb 09, 2010 | Samsung SPH-M800 Cell Phone
    I bought a plantronics headset for my iphone and i want to desync it from my phone and give it to my girlfriend who has an iphone as well but im having a lot of trouble still can you help?
    Go to your Bluetooth settings (under Settings/General) and you can select the Plantronics headset and then click on 'Forget the device'. Your girlfriends iPhone will detect the Plantronics headset and you have to entire the pairing code which is typically '0000'. You should be good to go then.
    Jan 23, 2010 | Apple iPhone Smartphone
    LG KP500 and Plantronics 260 steroe bluetooth music
    want to use a Plantronics pulsar 260 headset to listen to music over bluetooth played on LG KP500 phone. After pairing the devices what settings do I need to change on the phone to make it play stereo music over bluetooth to the headset?
    May 16, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
    How to set my bluetooth up on my cell phone
    Go to: http://www.plantronics.com/media/media_resources/literature/user_guides/explorer300series_nasa.pdf
    May 04, 2007 | Plantronics Explorer 320 Wireless Headset
    Lands Phones Logo
    171 people viewed this question
    Top Lands Phones Experts
    Are you a Lands Phone Expert? Answer questions, earn points and help others
