Question about LG LRSC26920TT Side by Side Refrigerator
Ice tray where do i get the new ice tray #3390JA1150A
LG LSC26905TT.
How do I change the ice tray, it is bent.
Thanks.
Posted on Aug 08, 2009
    Champion:
  • 210 Answers
Contact LG Electronics or AP Wagner also sells LG parts.
Sgt 48
Posted on Jul 02, 2008
The ice maker overflows the ice tray, so water runs down the side of my freezer.
if it has worked for 3 years then I would guess just a new tray
Feb 18, 2015 | Kenmore Refrigerators
Ice tray won't eject ice
check the icemaker timer. replace with new if bad, thanks .
Aug 25, 2014 | LG Refrigerators
On my VISB542SS the ice maker , water leaks into the drawer when ice is being made, Ihave removed the unit to check for leaks bot find none.
The ice tray releases the ice because the mechanism twists the tray during the end of the cycle. Sediment builds up in the ice try over time and the smooth Teflon surface is no longer smooth, and the ice can get a "grip" on the tray. Then when the tray is twisted, a few cubes remain in the tray. When the measured amount of water then flows into the tray on the next cycle, it is too much. It freezes over the top of the tray, and the next time the tray is twisted, no ice falls out. When water is injected after this, it just runs off the top of the tray into the bin, freezing the ice in the bin. Replace the ice tray every 3-4 years with a new ice tray, and the problem disappears.
Do get back to us for any further query and do not forget to accept it.
Thanks for contacting fixya.com
Oct 15, 2010 | Viking Refrigerators
I have model 3XART720F02 ART706 TYPE 2055A The water ice distribution area needs cleaning. Can this area be dismanteled
Prepare the Ice Maker For Cleaning
Step1Lift the power located above the ice maker storage tray.
Step2Unplug the refrigerator.
Step3Allow the refrigerator and to defrost. This will melt any large blocks of ice that have accumulated in the ice maker
Clean the Ice Machine
Step1Remove the ice machine storage tray.
Step2Dump any water in the ice machine storage tray.
Step3Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
Step4Sanitize the lines of the ice maker. Consult your manufacturer's
directions for steps to do this, because it's not available on all models.
Reassemble the Ice Maker
Step1Replace the ice machine storage tray.
Step2Plug the refrigerator into the outlet to restore power.
Step3Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
How to Clean an Ice Maker
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 21, 2009 | Whirlpool Refrigerators
Ice maker not ejecting ice and then tries to fill tray and leaks
The Ice Maker Tray had a small plastic piece break off. This piece aids the tray in bending to dislodge the ice from the tray. Bosch does not just sell the tray, you will have to buy the whole ice maker assembly. You will need to order Part # 0422 from Bosch. I was not very happy about having to spend $112.00 for this whole assembly when all I really needed was a simple ice cube tray.
Save the $112 and remove the ice maker. Buy Ice at the grocery store.
Mar 31, 2009 | Bosch Evolution 500 B20CS50SNS
LG SXS Refrigerator LSC26905 ice maker
I was able to order the ice tray myself and install it in the fridge - it's not hard. I ordered from one of the parts sellers linked to at the LG website, not those listed in other posts here.
Here's how to replace the tray:
You need to remove the tray dumping mechanism to do this.
  1. Remove the ice bin, set it aside (don't forget to deal with the ice melt).
  2. Turn the ice maker off (LG says to unplug the fridge, I didn't).
  3. On the left hand side of the ice tray dumping mechanism there is a screw helping to keep the entire thing suspended from the ceiling of the freezer. Remove that screw- don't worry, the mechanism will stay put for now.
  4. The dumping mechanism can now slide forward- note that you can't completely remove it from the freezer yet, but slide it forward and it will no longer be suspended from the ceiling. Don't let it drop or hang.
  5. You need to disconnect its power supply now. On the left hand side you should see a small bundle of wires coming from the back of the freezer to the dumping mechanism. It connects to the dumping mechanism's set of wires with a pair of white plugs. Pull these plugs apart. You may need to pry the catch on these plugs apart while you pull.
  6. Now you can take the dumping mechanism out of the freezer (and close your freezer).
  7. To remove the ice tray you need to slide the housing that contains the rotating motor out of the housing. This is on the right side of the mechanism. If you have trouble identifying it look at the underside of the entire thing and you'll see a small "test" button. That button is on the motor.
  8. To remove the motor you'll see two catches on the right side- you'll need to pull these catches out without breaking anything. You'll be able to slide the motor down and out when you get it right.
  9. Sliding the motor out lets you get the old ice tray out now. There is probably a set of white wires routed through a little catch on the old ice tray that you'll need to free.
  10. Put the new ice tray back on the motor. You'll need to get the left side secured at the same time you get the motor housing in its catches of the dumping mechanism.
  11. Reroute those white wires back on the new ice tray.
  12. Reconnect the electric wires to the housing.
  13. Slide the entire dumping housing back onto the ceiling of the freezer and screw in on the left side.
That's it. You can press that test button on the underside of the motor. This will dump the tray and immediately refill it with water so you can observe if everything is working.
Jun 03, 2008 | LG LSC26905TT Side by Side Refrigerator
Ice maker freezes up and drips water
I am assuming you have the ice maker that the tray twists to release the ice. There is a new tray out with a wall to prevent the water spilling over. The part number is
3390JA1150A
Sgt 48
Mar 09, 2008 | LG LRSC26980 Refrigerator
Ice box
In the LG side by sides they have developed a new ice cup tray. The tray has a little wall so that the water stays in the tray and doesn't go onto all of the ice causes it to stick together.
part number is 3390JA1150A
Sgt 48
Feb 08, 2008 | LG LRSC26920TT Side by Side Refrigerator
Ice tray sometimes stuck when dumping off ice
I had the same problem. I did the following and it now works great. The ice tray has a square tab on the rear leftside. As the tray rotates to dump the ice, the tab runs on a curved section of the the ice maker frame. The curved section becomes rough with use and causes the tray to stick when it is returning to the fill position. I carefully sanded the curved section of the frame to smooth it out. No problems since.
One does have to dismantle the ice maker to effect this repair.
Mar 09, 2007 | LG LRSC26980 Refrigerator
Ice Maker Dumping Water into Collection Tray.
LG has a new ice cube tray that will solve this problem. The part number is 3390JA1150A The wall will stop the overflow.
Sgt 48
Feb 19, 2007 | LG LRSC26944 Side by Side Refrigerator
LG LRSC26920TT Side by Side Refrigerator Logo
293 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
