Is this problem occuring on a laptop keyboard?
--If this problem is occuring on a laptop keyboard, then it's possible that cleaning will help with the problem. Use canned air and/or a lint free cloth damp with dilluted (10%) isoprophyl alchohol. make sure it's completely dry before plugging it back in. Also ensure that your "function" key isn't stuck or locked and causing the problem.
--If the problem is with a desktop keyboard, then one possible cause would be key-mapping software (depending on your model of keyboard, some higher end allow for the keys to be re-mapped to a new value), make sure thatyou don't have any such software enabled on your system. Otherwise, you could try cleaning to fix the problem but it's unlikely that it would help. If nothing above helps your only real easy solution is to buy a new keyboard for your system.
I took the letters off my keyboard (old Apple white) to clean. Now all the keys with the metal clip...
(More)
I took the letters off my keyboard (old Apple white) to clean. Now all the keys with the metal clip underneath aren't working right. Is there an easy solution save buying a new keyboard?
EG.
If i press s it appears as sg
If i press w it appears as wt
If i press t it appears as...
(More)
EG.
If i press t it appears as wt
If i press x it appears as xb
I have problems only in 2 columns column 1 : 2wsx
column 2 : 5tgb
other keys are absolutely find. Kindly find a solution,....
my wife just bought an activa keyboard, but she's having problems installing...she has windows...
(More)
my wife just bought an activa keyboard, but she's having problems installing...she has windows 98...can anyone help?
