Question about Refrigerators
Maytag GC2225GEKS refrigerator not cooling.
This refrigerator has had to have the controller replaced and 6 months after the compressor now only works when refrigerator side door is opened.
If we shut the door and then switch on it will not cool. The fans start and then the compressor very briefly runs and then stops. If we switch on with the door open it cools and even makes ice in the freezer ice maker. When the door is closed there is a loud click from the control board area and the compressor immediately stops and will not start again.
How might I fix this problem? Will the control board need to be replaced again?
  • geoff89 Jul 01, 2008
    I have now removed the door switch and bridged the connection to keep it running. So far so good but the lights stay on. I'll wait until it stabilises to see if the compressor continues to work correctly.
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
applianceboy
  • 77 Answers
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Posted on Sep 26, 2007
fridgetech
  • 473 Answers
SOURCE: Admiral Refrigerator makes hollow ice
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
Posted on Oct 05, 2007
dididsaythat
  • 291 Answers
SOURCE: Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Posted on Oct 14, 2007
  • 3 Answers
SOURCE: lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Posted on Mar 30, 2008
Model MBF2255KEW Refrigerator is not cooling. What are some things we can try to see if it will reset?
First, unplug the unit for 10 minutes to reset the electronics.
Second, replug and set controls to cold settings.
Third, if compressor is working you should hear noise to confirm.
4. Check fan is running efficiently with no noise. If not, replace fan motor and recheck.
5. Check damper control unit is working (see diagram in owners manual) if you have it handy or download it online from below.
Maytag Kitchen Laundry Home Appliances
6. If compressor is running, strange noises are heard, or unit shuts down after start-up, or fails to start, either the compressor has a leak resulting in a no pressure automatic shutdown or the electronic control unit is faulty.
Unfortunately, there is no quick fix for either and a Certified Repair Technician is required to either fix or generate a Warranty Replacement Claim.
Apr 22, 2017 | Refrigerators
Maytag refrigerator not cooling
HI,
You have a new design cooling system the runs on a 230 inverter with a DC compressor. So Check the red and black wire to the inverter for 110 volts or better to it. If you have this voltage, replace the inverter only as it has failed to run the compressor. I hope this helped. Parts number is W10285954, this is not a cheap part but controls the compressor run. Good Luck
Aug 31, 2014 | Maytag MFT2771WEM
Refrigerator not cooling
replace the ptc overload/relay on the side of the compressor this aids in starting and running of the compressor
Jan 12, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
I have a maytag side by side refrigerator that is not cooling at all i replaced starter relay and capacitor still doesnt work compressor doesnt worke
If you are not even hearing the compressor trying to start it could be the defrost control. It is located under the upper panel in the refrigerator side. Not a easy change out however.
Jun 03, 2011 | Maytag MZD2766GES Side by Side...
I'm having trouble with Maytag model MF12067AEB refrigerator that started about 6 months ago. The vegetables/fruits are freezing in the bins....the repairman has been to my house 3 times....replacing the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Maytag Refrigerators
Have a MFD2561HES refrigerator and both the
i would call who ever replaced your compressor usually they warrant their work for maybe 3 months or so he might have had a bad weld he made when joining tubes,,, it is worth a shot
Jan 31, 2010 | Maytag Refrigerators
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Maytag, side by side refrigerator stopped working
Check the thermostat which is located in the top left hand coner of the refrigerator. Also check the relay on the compressor to make sure it is not staying open all the time. Also there has been a huge recall on Maytag side by side refridgerators made between 2001 and 2005. I would also try calling Maytag and get the problem fixed by them by recall
Apr 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
NOT COOLING IN THE REFRIGERATOR
Yes it could. On most refrigerators the condensor fan is always on when the compressor is. If this is computer controlled it should still come on shortly after the compressor starts. If this stays off the compressor will overheat and cycle on the overheat/overload sensor. THis would definately cause your symptoms as on most boxes all cooling coils are in the freezer and the fridge is cooled by cold freezer air. On a computer controlled model it could be programmed to cool the freezer first then let some down to the fridge.
Jul 03, 2008 | Maytag MSD2756G Side by Side Refrigerator
Fan runs but no cool air on both freezer side and cold side
If you hear the compressor try to start then click off, you probably have a bad compressor or a bad relay. If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge. The relay is only covered for a year. With it being a Maytag, I bet it is compressor. There have been a few models with control board problems that have caused this symptom, but that's not likely to be your problem.
Oct 06, 2007 | Maytag MSD2756GES Side by Side...
Refrigerators Logo
206 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
