Hi, I have a canon mx310 printer which won't print. I changed the cartridge and it said it was printing a report but didn't print or do anything and and now it says please wait momentarily and won't allow me to turn it off or reset it. cheers Sharyn
  • creekyaust Jul 01, 2008
    thank you so much for your prompt reply :)
    Genius:
  • 2,785 Answers
Plz unistall your printer and reinstall it, if the problem after reinstalling then do a viruses scan
Posted on Jul 01, 2008
When attempting to print, my Canon MX310 seems to run fine, but the paper is blank. No errors reported, but just blank paper
Have you tried running the clean heads and prime functions. If the printer has set for a while, things may have dried out. Or, perhaps the cartridges are out of ink?
Jul 19, 2016 | Canon Office Equipment & Supplies
I have a PIXMA iP4300 and just want to use it for black and white document printing. My 'M' and 'C' color cartridges ran out a while ago and I disposed of them but didn't replace them...
Most of the Canon printers form the PIXMA iP series block printing when one of the cartridges is empty. You have some options: 1) change the cartridges (with original or compatible) 2) buy a chip resetter and reset the empty cartridges chip so they can cheat the printer that they are full. This way you will clog the nozzles of your print head and the printer will become useless and won't print.
That's why I suggest you to but even cheap compatible cartridges and replace them.
Hope this helps. Alex
Sep 11, 2011 | Canon Office Equipment & Supplies
One colour won't print. tried new cartridge but
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Aug 12, 2011 | Canon PIXMA MP810 All-In-One InkJet...
Canon mx310 how to print color document in black
When you go to save it or just before that you select file then go to print properties under that there should be a selection to print it in black and white.
Let us know ether way but its done under printer properties.
Thanks and please do be considerate that we are trying to help when you leave your positive ratings and feedback, thanks
May 26, 2010 | Canon PIXMA MX310 All-In-One Printer
Trying to change from black and white printing to color on canon mx310 please please help
Go to Cannon My Printer file, Click Printer Settings, Click Maintenance Tab, Click Ink Cartridge Settings, Select the ink cartridge for printing, Hit ok.
Apr 02, 2010 | Canon PIXMA MX310 All-In-One Printer
How do I print an Activity Report for faxes sent on the Canon Pixma MX310?
Hi ...
The fax machine prints an activity report automatically after every 20 transactions. To print a report manually, follow these instructions:
1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select [ACTIVITY REPORT], then press <OK>. The ACTIVITY REPORT is printed.
Don't forget to vote if this helps ... Cheers :)
Aug 02, 2009 | Canon PIXMA MX300 All-in-One Printer
Our Canon MX310 printer is flashing Waiting For Report and the In use/memory light is on all the time. There are not reports to print as far as we can see
  1. Remove all print jobs at your computer
  2. Turn off printer
  3. Disconnect printer power supply
  4. Wait 30 seconds
  5. Reconnect printer power supply
  6. Turn on printer
May 07, 2009 | Canon PIXMA MX310 All-In-One Printer
How do you turn off the in use/memory light?
This of course depends on why the light is on! If you had a fax come in and it is in memory, you will need to print the fax and clear the memory before the light will go out. The LCD Display should be telling you why that light is on.
1. There is a fax or print job in memory waiting to be printed.--> See steps below
2. There is a paper jam --> Open printer - Remove all paper - Close printer - press OK button
3. You are out of ink or the cartridges are low. - Change Cartridges
Solution: Printing reports and lists MX310
The table below shows the reports and lists that can be printed from your machine.
Report or List Description ACTIVITY REPORT Shows recent facsimile transactions performed by your machine. You can enable or disable automatic printing of this report after every 20 transactions. You can also manually set the machine to print it. CODED SPEED DIAL
LIST
Lists the destination numbers and names registered for coded dial speed dialing. USER'S DATA LIST Lists the current settings of your machine and the registered sender information. MEMORY LIST Lists the documents currently stored in the machine's memory. TX (Transmission)
REPORT
Prints after transmission of a document.
You can enable or disable this feature, or set the machine to print a report only when an error occurs.
You can also set the machine to print the first page of the document under the transmission report to remind you of the contents of the document.
RX (Reception)
REPORT
Prints after reception of a document.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Mar 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Not printing
did you remove the safety tape from the cartridge ?
Dec 23, 2008 | Office Equipment & Supplies
Canon MX310 Printer - How to reset to factory settings?
usually there is a menu in the printer itself. does it have its own little screen? if so go to tools or setup n look around to find default or reset n hit ok.....lemme know what happens
Sep 29, 2008 | Canon PIXMA MX310 All-In-One Printer
80 people viewed this question
k24674
jasbo
jasbo
