Question about Amcor A12000E Nanomax Portable Air Conditioner
Amcor Air Conditioner doesn't get cold!
I hooked up my Amcor unit and turned it on, and it doesn't get cold..not even cool.
Please advise..
Thanks!
Steve
kstfas
  • 75 Answers
SOURCE: cooling problems
Check the filters inside and the evap coil to make sure it isnt filthy. The evap coil can be cleaned with a credit card if its wet. The large line outside should sweat all the way to the compressor if its got enough freon. Will freeze when its cool outside or not sweat at all if its low. Good luck with it.
Posted on Jul 30, 2007
SOURCE: Sunbeam floor air conditioner KY25/Y
Mine is cooling but I have a broken fan. If you're not going to use it sell it to me please. contact me at yenks@hotmail.com
Posted on May 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: Hampton Bay air conditioner wall unit doesn't cool
Might be the CAPACITOR
Posted on Jul 01, 2009
  • 22 Answers
SOURCE: amcor af11000e air conditioner. The fan runs, but
it is either the capacitor or it has no freon you can replace cap but not add freon not worth it. you should return it if you can
Posted on Aug 07, 2009
shafykp750
  • 1070 Answers
SOURCE: my air conditioner gives out cool air not cold air
Welcome to FixYa
Check the Following
Is your filter clean? Look and the evaporator in the inside unit. Is it frosted up? Do you have condensation water in the pan? Go to the outside unit and feel the air coming out of the fan. Is it warm? Now feel the 2 copper pipes coming out of the unit. Is the small one warm or hot? Is the larger one cool ? Is there moisture on it?
Air conditioner runs but doesn't cool at all
If the airflow is good and the air coming out is not cold, your home air conditioning problem may be a temporary problem - your coils may have frozen. Turn the unit off for an hour to let them thaw, then try again. If cold air is now present, freezing coils were the problem; if the problem recurs soon after turning on, you may need to replace the coils. Again, call a pro. If you have ceiling vents in upstairs rooms and the air flowing from them is consistently warm, you probably have leaky or poorly insulated ductwork in your attic. See my Attic ceiling insulation page for more information on insulating ductwork that runs through attics.
Another likely home air conditioning problem if you have good airflow but no cooling is that the breaker to the outside unit is shut off, which, depending on the installation, can either cause the air conditioning system to not run at all, or to appear to be running but not provide any cooling. If you can hear the compressor fan running outside, the breaker is on, but if the outside unit is silent the outside breaker may be off. If switching it on does not solve the problem, look for the high pressure cut out on the condenser and try resetting that.
Check this Link for Detailed Repair Click here
Also Check this Link
Hope this make you better..Thanks for Contacting FixYa...
Posted on Jun 27, 2010
Testimonial: "out of three experts i should have stayed with shafykp 750 he was the most informative and thourough"
I have an AMCOR ALTL1200E, fan works, cold air comes out when the compressor turns on BUT after 5 minutes compresor turns OFF, then after 5 minutes again it turns on, what is wrong, thanks
Sounds like the unit is cycling off on a high head pressure (condenser coil too hot). When the condenser cools, the automatic switch resets. The unit cuts off again when the condenser heats up again. Clean the condenser coil, and clear out any debris (bird's nest, lint etc.)
Aug 30, 2013 | Amcor ALTL-12000E Portable Air Conditioner
Water fill area
Compressor is working and it goes on and off. There is a air coming out, but not cold for this 11,000 btu. I also need a longer exhaust hose. Please advise. Unit works great when functioning.
Aug 04, 2012 | Amcor A12000E Nanomax Portable Air...
I want to hook up a permanent drain system. Where can I find a hose which will fit onto the drain plug of my PMMB14000E?
Your unit is not intended or approved to have a continual draining function. Some water must remain in the unit, to cool the coils during the cooling operation.
Hope this helped you and thanks for choosing FixYa.
Aug 09, 2011 | Amcor 14000 Portable Air Conditioner
The unit does not blow cold air any more. Inside is sometimes hotter than outside. will be 85 inside but 80 outside. Have thoroughly cleaned filters, but no change. "comp" light is on
Hi, The compressor has gone bad and it will cost more to replace it then the unit is worth... buy another unit and buy anything BUT an Amcor unit... they are junk!!
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Amcor AF9000E Portable Air Conditioner
The unit will not produce cold air. It only pushes out room temp air. Altough I am not an expert, I think it is the compressor, or the tempature control unit (thermostat?) The unit does seem to make an...
I have a Amcor AF 1200E air conditioner, it only blows warm air and it is real dirty on inside filters, we took out 3 filters but there is still dirt on filters behind these, do we take it apart to clean, I would like a manual , do youknow where I can download one at? thanks
Sep 06, 2010 | Amcor AF9000E Portable Air Conditioner
Parts for Amcor Portable Air Conditioner
Your parts can be found at amazon, click here and take a look: Finally charging for our multi device world. I hope this was helpful. Cheers
Apr 30, 2010 | Amcor AF9000E Portable Air Conditioner
Ive got an amcor air conditioner, will it blow hot air aswell as cold,
If it blows hot and cool air, it means that you aircon is
not having an isolation of the evaporator and condenser
air. Please have a technician repair the air leak. Hot air from the condenser must be separated from the cool air
of the evaporator. Hope this will help you.
Jan 04, 2010 | Amcor PLM-14000E Portable Air Conditioner
Amcor A12000E Nanomax Portable Air Conditioner Logo
141 people viewed this question
Top Amcor Heating & Cooling Experts
Donni Steen
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
