Question about Casio Parts Cash Register PC Desktop
Tax2 programming We having problems programming our tax2 button. The instructions we were given from our register guy always makes our cash given 50.02 and then makes the change from that. Please help- quick
  • 737 Answers
Hi.
You have not mentioned the model.
Also, is your tax 1 working correctly? A program read of tax1 may help to see where you are going wrong.
If your CASH key is doing tht, it sounds like you have programmed your CASH key instaed of your tax.
Let me know all the info you can, including what you did while re-programming, and I'll see if I can help.
Model number especially!
Posted on Jul 01, 2008
How do I add another tax (county) to my register
You set a tax rate to the next tax setting available e.g tax2. Then you link each product that uses that tax to T2 in the settings for the product (usually PLU prog). There will be various codes to do this in your manual. If you have lost it, one of the users has most programming manuals here:
https://the-checkout-tech.com/
May 27, 2016 | Retail Supplies
Hi how do I program the taxes for Quebec (5% and 9.98%) into my casio pcr-t275?
Use the rate programming codes for tax1 and tax2. Once you have set the rate, you need to link each tax to a department using the codes for department linking. If you have lost your manual, one of the users has the tax code manual here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T275_users_manual.html
Jun 18, 2014 | Casio Parts Cash Register PC Desktop
Wan to canche vat from 18 to 19 percent
You need to follow the table for tax rate programming. If you use multiple taxes, set the rate for tax1, tax2, or tax3 etc. Most VAT is done via tax1 only. If you have lost your manual, most cash register manuals are here http://the-checkout-tech.com/
Jan 10, 2014 | Casio Parts Cash Register PC Desktop
How do i program different tax rates for different departments
You just link the departments to the tax rate in department programming. You will see tables with TAX1, TAX2 etc. You turn on the tax you want for each department using the codes in the manual. If you don't have a manual, most cash register manuals are here:
May 22, 2012 | Casio Parts Cash Register PC Desktop
How to fix e035 error on se-s2000
I tried your suggested fix Electroboy and all it did was print out some end of year totals or something that used about 5 metres of paper, I managed to get help from the Hotpos tech support guys and they gave me this sequence which immediately fixed the problem......
Turn key to program
Press
subtotal
0
0
0
0
cash
subtotal
Turn key back to reg
That's it :)
Apr 11, 2012 | Casio Parts Cash Register PC Desktop
Casio PCR-T280 Help with Taxes and Departments.
In department programming, there is an option to turn on or off each tax. You need to turn off tax1 and turn on tax2 (if that is the one you have programmed for the rate you need). Just look up the tables for tax rate and department programming in the manual. If you don't have one, C-tech has it listed here:http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T280_operating_and_programming_manual.html
Jan 28, 2012 | Casio Parts Cash Register PC Desktop
Hello, I have a cash casio PCR-T275 I want that tax2 is taxing tax1. By example, if I have: 10$ tx1 (5%) = 0.50$ subtotal: 10.50$ tx2 (8.5%) = 0.89$ (tx2 applicable on tx1) Total: 11.39$ (NOT...
While you can't have the second tax rate tax the first as you described in the example, you could program the %+ key to be your first tax of 5% and program the tax rate 1 to be 8.5...so ring $10.00, then hit the 5% service chg,(programmed to be taxable by rate 1) then subtotal...should tax the whole amount
Jan 03, 2011 | Casio Parts Cash Register PC Desktop
Remove Casio PCR-T2000 Tax Table 2
Hi. You are working in the wrong area. You need to tell each department not to add TAX2. Go to the department programming, and there should be a setting that says use tax1, use tax 2 etc. Turn off tax2 for any depts that you don't want it added and it will no longer print or calculate tax 2 for that department.
For anyone looking for a Casio PCR-T2000 manual, see here:
http://the-checkout-tech.com/manuals/cashregisters/Casio2.php
Feb 06, 2010 | Casio Parts Cash Register PC Desktop
Tax problem
It sounds like you have only one tax set to the item button that you are using. You need to check that you have tax1 and tax2 linked to that item.
Mark
Mar 01, 2009 | Casio Parts Cash Register PC Desktop
Casio Register 265P - Doubling Tax in Sales Total
Hi.
That could be tricky. we will need to go through the tax setup in your machine.
My first questions are:
1. Does it happen on all department (item buttons)?
2. Does it happen no matter what payment method you use (cash, check,credit)?
3. When you push Subtotal, does it show the wrong amount then, or only when you press a payment type to open the drawer?
Mark
Nov 12, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
74 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
