Question about Philips HTS-6500/37 System
NO SOUND WORKED FINE TURNED ON TODAY NO SOUND OUT OF ANY SORCE JUST HISS
I did not but it said free help so I didnt bother
Posted on Jul 02, 2008
My 09 HHR a/c quit working and is blowing hot air even when the fan is off. I hear a click coming from the dash right before it blows hot air. and today I noticed a hissing sound
That hissing sound is the vacuum line knocked off the servo that shuts off the heater core so the AC will work more effeciently. Your getting warmer.
May 11, 2011 | 2006 Chevrolet HHR
Occasional hissing noise from a/c 2000 gmc sierra
This is pretty normal, the way the system works is by forcing liquid freeon through a orifice, the liquid turns to gas and gets very cold, the hissing is that process. You might be a tad low on freeon, but you shouldnt be worried.
Apr 05, 2010 | 2000 GMC Sierra
Similar hissing sound
THE HISSING SOUND IS THAT THE A/C SYSTEM IS LOW ON REFRIGERANT..YOU MORE THAN LIKELY HAVE A LEAK IN SYSTEM..THESE VEHICLES HAD SOME ISSUES WHERE THE LINES GOING TO THE REAR EVAPORATOR ARE LEAKING WHERE THE LINES GO THROUGH THE FLOOR INTO THE HOUSING..YOU NEED TO HAVE SYSTEM LEAK CHECKED
Jun 12, 2009 | 2000 Plymouth Grand Voyager
Anti-lock and trac-off lights
It could be a loose wire under the hood or dash. Was there any smell associated with the pop-hiss? It sounds like there was a short in the main power somewhere that literally killed your engine and then let it restart under it's own momentum. Hence the blackout and reset of the main computer.
Sep 27, 2017 | Buick Regal Cars & Trucks
Hissing sound coming from speakers
I found out that if I manually turn the speakers down on the tv and then turn it up with the remote control the hissing sound goes away
Mar 18, 2009 | Toshiba 65HDX82 65" Rear Projection...
Hissing sound from a Panasonic old TV...Sound and picture are OK. The hissing sound even continues when the MUTE on the Box is ON. The hissing only stops when the MUTE on the TV is ON. I am using the...
If you disconnect or power off the converter box does the hiss go away?
If you connect a VCR or DVD player does it still have the hiss? We
need to isolate what source is causing the hiss if it is from the set or
if it is from the converter box.
When you turn the volume control down on the set, does the hiss
reduce in level? If mute stops it, it should reduce in level as you
turn the volume down. Then turn up the sound level control on
the converter box whether its a manual control or by remote. If you
can get a combination that minimizes the hiss and gets higher sound
level from the programming that may cure it.
I am not familiar with the converter box you are using. Are you using
Audio/Video cables from it to the set or is it coming out with coaxial cable
and used on a channel? If you are using a very old set with a tuner input
perhaps the fine tuning is out of adjustment.
Feb 21, 2009 | Panasonic CT-20D11 20" TV
Speakers hissing/humming
Hi Nate41
you won't do anithyng
may be is a bad resistor inside, that get hot and probably start to do this problem. try disconecting the speakers, and move to other place, more cooler, and try to see if you don't get the hissing and humming sound now. sometimes dust and hot places get to this problem.
beside that, may be a path to a problem.
Nov 26, 2007 | JBL CREATURE II Computer Speakers
Sony kp-41s3u 50" hissing sound
sounds like high voltage arcing,caution
Oct 28, 2007 | Sony KP-41T65 41" Rear Projection...
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
TV wont turn on?
this product has a bunch of exotic semiconductors that only a tech could replace in my parleyance its called NECO
Dec 08, 2006 | RCA 27R410T 27" TV
Philips HTS-6500/37 System Logo
169 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
