Question about RCA OPAL M4001 MP3 Player
Mp3 problems my mp3 won't charge and my computer won't read it anymore
  • 8,596 Answers
Make sure lock is not engaged
Reset, double-check firmware, check Recovery Tool from RCA's website
Posted on Jul 06, 2008
My h10 won't start anymore!
My I river H10 won,t start after purchasing a new battery for it.The charge light on the charger is dim
Nov 24, 2012 | iRiver H10 MP3 Player
Why won't my mp3 coby player won't charge
Your coby is not charging anymore..The battery probably needs to be replaced with a new one..Please check your connection when you charge it..There should be an icon that shows your battery is charging. If it does so that means your coby is charging but your battery cant store the energy anymore.
Feb 19, 2012 | Coby MP-610 MP3 Player
Sony walkman Sony Walkman Bean NW-E305 (512 MB) MP3 Player won`t charge
Good morning, afternoon, evening or night; whatever time of day you are reading this solution post. Thank you for choosing FixYa to assist you with your problem. Your Sony Walkman Bean NW-E305 (512 MB) MP3 Player won't charge properly? Well Danish, we must use a method called troubeshooting to figure out and solve this situation. There are several reasons why this player may not be charging properly. The cause is either coming from the battery inside of your MP3 Player, a bad or faulty USB cable connection, or something (software) isn't installed correctly. Let's look at the first cause- The battery. The battery life may be gone. If it is, you will need to replace it if possible. Your device takes a
Sep 26, 2011 | Sony Walkman Bean NW-E305 MP3 Player
Battery in my zen v plus mp3 player won't charge
Two possibilities come to mind: (1) your battery has outlived its usefulness. This is not good news for, from what I understand from various posts on Amazon, Creative will not service its products anymore--not even battery replacement! ; (2) I recall reading on Creative's support page that even if a good battery is overly discharged, the computer won't recognize/recharge it assuming you are charging off a computer USB port. In this latter case, all is not lost since there are cheap cigarette lighter 12 volt plugs which reduce to 5 volts and will recharge mp3 players, or, 120 volt to 5 volt converters are also available. Either of these will bring an otherwise good but overly discharged battery back to full charge and this should solve your problem. If not, you are out of luck.
Feb 15, 2011 | Audio Players & Recorders
Mp3 not charging when connected to the computer
well it sounds like the problem i had last year. (mine is corrupted)
Sep 25, 2009 | Sony Walkman NWZ-S616F MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 4GB MP3 Player
go to control panel and click on portable media devices note:will not work on windows xp even if you downgrade to classic using a disk
Feb 07, 2009 | SanDisk Sansa Clip MP3 Player
Ipod not getting connected to itunes nor getting charged, and please recommend which ipod converter to download. Thank you in advance
winamp and itunes which you have all ready if that not reading it then no outher program will . ? is your computer reading it ? if not sure go to my computer right click and open it in there you will see drive G if not that the reason why itunes won,t pick it up and no outher program will what you need is a hub carrier with it own power sorce all mp3 need 2.0 in order to work properly
Feb 11, 2008 | Apple iPod MA446LL/A MP3 Player
Recharging mp3
Whenever the PD-6070 is connected to a PC, it will charge. The battery indicator on the OLED screen will slowly fill over and over as it is charging. When the charging is complete, the battery indicator will stay filled.
Jan 18, 2008 | MyMusix PD-6070 MP3 Player
RCA OPAL M4001 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
