Question about Toshiba Computers & Internet
It seems like my fan is running awfully hard. The exhaust also seems to expel really hot air. I had the fan replaced about a year or 2 ago. Wondering if I need to have it done again. Or what the problem is. It is a Toshiba Tecra A 1
    Scholar:
  • 83 Answers
It seems like my fan - sp.gif sp.gif Temperature Operating: 5°to 35°C (41° to 95°F); Non-Operating: –20° to 65°C (-4° to149°F)
Replace the fan.
Posted on Jul 01, 2008
I want to buy portable air conditioner, but the buyer said that i need put the exhaust tube near a window open to expel hot air, in my room not have windows
You do have to use the exhaust tube, would need to put a hole in your wall. Also, these units really generate a lot of heat. We tried one, it almost seems as if it actually makes the room hotter! You would be better off buying a small regular unit, constructing a hole in the wall to the outside.
If you absolutely cannot do the hole, you could get an extension to the exhaust tubing and maybe use a window in another room?
Apr 04, 2011 | Heating & Cooling
Hard to start when it hot
MOST OF THE TIME THIS THE MODULE UNDER THE DISTIRUTOR CAP THIS ONE PART OF THE TUNE UP....8 0OUT 10 TIMES THIS WHATS WRONG ABOUT 25 DOLLARS
Mar 01, 2011 | GMC G3500 Cars & Trucks
I have a mercury sable 2003 recently replace both cooling fans had raditor flushed and new termostat replaced and till over heats not sure if fans are working right
run a hot wire from the battery to the pos on the fans, if they start, then the fans are okay,poss the temp sensor or have you undone the topmost hot pipe clip to expell any air in system?
Jul 23, 2010 | 2003 Mercury Sable
Rattling noises from ac
If you are careful unplug it, tilt it 45 degrees back and use a hose spray sideways to remove the debris from the coils. It worked for me. Be careful not to get any of the electrical parts wet.Low pressure from hose
Jul 03, 2009 | Maytag Portable Air Conditioner M6P09S2A
Rinnai 1004F Heating the Outdoors!
Do you have the Economy button on? If so, and you have a large space to heat or the outside temp is very cold the unit may not be able to keep up. If this is the case the stove runs forever, trying to reduce the temp by 2 degrees every 30 minutes. This may not work for your space and outside temp.
Your ideas about the intake and exhaust are not quit right. There is a fan that pulls air from outside over the outside of the exhaust pipe (to preheat it). This fan actually pushed the combustion gasses all the way out the exhaust. The exhaust exiting should be a little hot. In very cold temps, frost can build up around the air intake, which is right around the exhaust pipe. If you see this you will need to keep it clean. It is a good idea to look at the exhaust everyday when it really cold.
Good luck,
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Jan 10, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Fan not going on and interface really slow
turn it off for an hour see if that works could be overheating
Dec 21, 2008 | Dell Latitude C400 Notebook
Exhaust Fan (outdoor blower?) shuts off after 1 minute, and motor feels hot
sounds like your condenser fan (the outside blower) has gone bad or the capacitor (small silver box looking thing attached to the motor). the way to test the cap. is with a digital meter that can test for micro farads. the reason it gets hot is you have electricity going to the motor. normally it would transition that energy to motion energy. however since the motor is not turning that energy has to go some where, so it turns into heat energy. your best bet is to replace your condenser fan and capacitor. that is if your comfortable with that type of repair. otherwise call someone out to repair and tell them what your make and model is so they can bring the parts with them and save you some money. hope that helps
Jun 11, 2008 | Goodman Heating & Cooling
Meile espresso maker does not expel air
Press Hot Water and Steam Button at same time.
Dec 24, 2006 | Miele CVA615 Espresso Machine
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
