Question about Brother MFC 420CN All-In-One InkJet Printer
Brother MFC-440Cn Do you have a parts breakdown for this printer? I want to remove the cartridge contol board and replace it, but not for sure how to remove all the covers.
the kowalski
  • 86 Answers
SOURCE: error 46 in brother mfc-440cn
Machine Error 46 ("Unable to Clean") indicates that the wasteink is full. Basicly it gives you two options - have it replaced (a semi-complicated performance which requires buying a spare part and change it yourself) or have it sent to service. If you do not have any warranty on the machine, the more suitable would probably be to just replace the machine instead, since it's relatively cheap compared to both service costs and having the wasteink replaced, but you instead get a full new warranty on your new machine.
Unfortunately, there's nothing you yourself can do to remove this error, without actually changing an item inside the machine.
Posted on Jun 04, 2009
  • 159 Answers
SOURCE: my brother mfc 440cn read unable to clean error46
Its Ink Absorber Box is full. Inside the machine, in the back and hidden under the covers is a large plastic box with thick, felt pads packed in it. Every time the machine cleans its printheads, it squirts ink through all its nozzles, collects the mess, and pumps it into that box. After a few thousand cleaning operations, it decides the box is dangerously full of ink and throws up that Error 46.
Getting to the Ink Absorber Box (part number LP1270001) is fairly complex. I think it's time to ask a tech what he/she charges.
Posted on Aug 05, 2009
  • 127 Answers
SOURCE: Brother printer won't recognize ink cartridge.
I use generic cartridges all the time in my brother printers with no problem. better to pay $2 per cartridge than whatever the brother brand ones cost!
Posted on Jan 05, 2010
cns assoc
  • 677 Answers
SOURCE: Brother MFC-440CN USB Printer double prints letters
Did you use Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine.
When they see it’s Generic Cartridges, it will print lines thru the words, mis-align the letters & put stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Jan 30, 2010
Jimsta01
  • 405 Answers
SOURCE: MFC-440cn brother printer error unable to print 4f
Problem with printer head or main board
Posted on Mar 29, 2010
Well i have a brother mfc -440cn and when im printing somthing the color doesnt appear to come out on the paper it comes out plain white
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
May 08, 2011 | Brother MFC-440CN InkJet Printer
Brother mfc-440cn not recognizing black cartridge
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Mar 28, 2011 | Brother MultiFunction Center MFC-440CN...
I have mfc 440cn. Do I need to replace the drum?
The MFC-440CN does not have a drum.
The only consumables this printer has is ink cartridges.
These wil need to be changed when they are empty.
Thanks,
Pat
Apr 07, 2010 | Brother MultiFunction Center MFC-440CN...
My Brother MFC 440CN will not recognize a Brother
The usual obvious fix is to buy a new catridge, insert, power off machine, then switch back on to reset any sensors. But if the circuitry on the machine itself is faulty it wont fix it.
I used to own an MFC 260C. It had a perfectly good full ink catridge in it, that was working fine, until...it suddenly did not recognise the cartridge anymore.
I pulled the machine apart and found that 2 of the 4 sensors on the cct board at the back of the cartridge housing were loose. These sensors pass light through the exposed part of the cartridge to see if ink is there. So if these are faulty, you will never clear the "No Cartridge" or "Ink Empty..." or "Near Empty Ink ..." messages on the MFC260C and prbably other similar printers in the MFC range.
Why did they fail? Because the soldering on these sensors was poor quality.
I would never buy another Brother machine because of this, also because they design the machine to be totally useless unless all the ink ccartridges are full. Shame on you Brother, and kiss my *** for the $160 pile of junk I bought off you that was only on its second batch of cartridges (ie very little use)
Jan 23, 2010 | Brother Office Equipment & Supplies
No black cartridge
Make sure you/ve completely removed the plastic strip covering the gold contacts on the cart.
Sep 12, 2009 | Brother MFC-440CN InkJet Printer
Only black cartridge empty, but 3 full color crtrige say empty
Remove the color cartridges. On one end you can see the opaque
ink tank inside the main cart. housing. Cut a piece of black electrical
tape to fit around the three sides visible of the ink tank. Make sure the tape fits inside the housing and adheres to the tank itself. This makes the printer think your ink is always full but you can always tell when you need to refill/replace the ink(right?). Good Luck!
Dec 27, 2008 | Brother MFC-440CN InkJet Printer
My MFC-440CN
Yes, an empty ink cartridge will prevent the printer from functioning.
Not all printers will do this, but the Brother MFC series will not print if any one of the cartridges are empty. Replace the cartridge and all should be fine.
Mar 07, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC 420CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
