Brother SX-4000 Typewriter Logo
Anonymous Posted on Dec 14, 2010
The keys typed are not the letters coming up
Norman Worley
Level 3:
Genius:
  • Master 1,273 Answers
  • Posted on Dec 14, 2010
Norman Worley
Master
Level 3:
Genius:
Answers
1273
Questions
0
Helped
324918
Points
3473
The SX 4000 is a "Daisy Wheel" printer. A plastic Wheel with the letters embossed on them spin via the input of the keyboard. I would suggest that your Daisy Wheel mhas slipped its index, presenting a offset letter., or the wheel is on inproper, but I do not see how it could happen, short of forcing it on. You may have to buy another Daisy Wheel, if that one is broken at the hub. See:
http://www.google.com/products/catalog?rlz=1T4SUNA_enUS250US259&q=daisy+wheels+for+brother+typewriters&um=1&ie=UTF-8&cid=5918209752341457784&ei=aqEHTeebDs6s8AaP-9nnAg&sa=X&oi=product_catalog_result&ct=result&resnum=4&ved=0CDEQ8wIwAw#
Testimonial: "Thanks, I'm pretty sure that is what happened. I appreciate your quick response."
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 24, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1831
Points
25
Hammer sticking & typing incorrect letters: WD40'd the hammer at the base & joints where moving parts are. kept typing until oil seeped in and it fixed it.
typing light and inconsistant-top part of letter okay but bottom too light or not there: to left of hammer are 2 screws, I losened them and adjusted hammer to different forward and backward spots..finally found the ideal location where full letter printed.
  • Anonymous Feb 24, 2013
    hammer sticking & typing incorrect letters: WD40'd the hammer at the base & joints where moving parts are. kept typing until oil seeped in and it fixed it.
When I type letter keys, numbers come up with the letters
That's because some are dual function keys; you've probably hit the 'Alt' or 'Fn' key to the bottom left of the keyboard by accident. If you look carefully at the letter keys, they should have numbers on them in a different colour/smaller text.
tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 • Cell Phones
tip
How to use Blackberry as a modem to acces internet?
1helpful
How to turn on numlk for gateway NE56R31u
You may have hit a certain combination of keys on your Gateway laptop and turned on the NumLock function accidentally. The result is that the rectangle of keys from the 7 key down to the question mark key have become a number-entry keypad. Worse, Gateway manuals don't discuss this function.
Hold down the "Fn" key on the bottom row of the keyboard, and press the "NumLk" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F11" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the F11 key and "Scroll Lk" key simultaneously. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F9" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "Scroll Lk" key. Type the letters UIO. They should come up as letters. If none of these help, then it's probably a keyboard malfunction and you'll need to get it repaired.
Letters i type on key board come up as different letters on paper. example if i type the word see, it comes up and types j;;.
On the L. side of the keyboard is the pitch slide switch it should be in 10 or 12 not PS.
DickyO
I have fujitsu laptop runing win 7, when i type some letter be wrong for examle when i type m come 0 ,
Hello there,
Did you check the keypad for alternate keys.
For example net books, the number keys on the right side has an alter key on the some letters like the image below. when you accidentally press the [Fn] key, Numbers are written instead of letters..
Hopefully this helps. Thank you for posting..
4helpful
2answers
Hye mr expert...Here i have some question about my samsung netbook n220 series. For your info...actually this problem never happen before.The problem is some of my key not working & some of my key...
The problem with your Netbook seems to be that you have turned "NUMBER LOCK" or "NUM LOCK" on. This causes some of the letter keys, e.g U,I,O,J,K,L,M to be printed as numbers 0,1,2,3,4,5,6.
To turn this off, hold down the "FN" key (near the bottom left of the keypad) and then press "F11" and then release both keys.
Please try this and post back if you need further assistance.
Regards,
BElectric
1helpful
3answers
Keyboard is not working properly-some of the letter keys also have numbers and when I type in a letter the number is coming up
look in bios, for numlock boot
thats why the number function works instead of the letter,
just got 16 odd at work and its my job to put xp pro on, with out a cd drive, if u need xp pro or another os hit me bk
Norman Weimar
Norman Weimar
k24674
