Samsung 120 gb hard drive reads smart feature failure imminent back up data immediately
    Scholar:
  • 83 Answers
You better back that up fast.
Posted on Jul 01, 2008
Error msg : smart failure predicted on hard disk 4
it simply means that you have a hard drive failure and data in it is already compromised. backup the data and replace it immediately before it stops working.
Mar 27, 2014 | HP dv9620us Notebook
SMART Failure Predicted on Hard Disk 0: ***************** Warning: Immediately back-up your data and replace your hard disk drive. A failure may be imminent. Press F1 to continue
this is the indication that your hard drive is failing in self monitoring and reporting tool which is done by the bios , in the initial booting time, its better you should replace the hard disk by backing up your data as soon as possible or if you don't want to see this message simple go on to your bios then disable smart option of the hard drvie
Feb 12, 2013 | Samsung HM500JI 500 GB SATA Hard Drive
SMART Failure Predicted on Hard Disk 0: WDC WD3200BEVT-75ZCT2-(S1) WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imminent. Press F1 to Continue
just means its time to backup all your information, as if the hard drive does fail theres a good chance you may lose some or all of your information.
hard drives aint that expensive around 30 pounds +
and you can replace it with any sata hard drive.
Jun 17, 2012 | Western Digital Computers & Internet
I have an ACER Aspire 5542 laptop and when I switch on I get the following message. "SMART Failure Predicted on Hard Disk 4 WARNING: Immediately back up your data and replace your hard disk drive....
Save your data asap and replace the drive it's failing. All drives fail over time you are lucky in that you are getting a notice. Others are not as fortunate.
Aug 30, 2011 | Western Digital (WD6400BEVT) 640 GB SATA...
SMART Failure Predicted on Hard Disk 0: st9100824as-(s1)) WARNING: Immediatelly back-up your data and replace you hard **** drive. A falure may be imminent. Press F1 to continue
Hi sqarrab,
A SMART Drive failure indicates that your hard disk is about to die. Sometimes it will last a few says, sometimes even months. Refer the link below for more information.
I suggest you keep a backup of all your data as soon as possible. Once the hard disk fails, there's nothing you can do to get your data back. To get rid of the message, buy a new hard drive, and then copy back all your data.
http://www.ariolic.com/activesmart/smart-failure.html
If this information was helpful, please rate it.
Thank you for using fixya,
Arun Zac
Nov 27, 2010 | Seagate (ST9100824AS) 100 GB SATA Hard...
Hi!im using a toshiba a210 laptop.i put it on some fews days ago it says "smart failure on hard disk 4-hitachi-(s1). warning:immediately back-up your data and replace your hard disk drive.a failure may...
Your drive is failing and you should back up any important data you need onto CD/DVD or an external USB device (hard drive/pen drive). The drive may keep working for a while but your system is warning you that it has detected a critical error with the drive and failure is imminent.
Jun 10, 2010 | Toshiba Satellite A215-S5822 Laptop
My laptop had a ''smart failure predicted on hard disk 0: toshiba mk4025gas-(pm) Warning: immediately back up your data and replace youre hard disk drive. A failure may be imminent'' what does this...
This means that your laptop's motherboard has detected that the hard drive (where all of your data and operating system live) is operating outside of normal parameters. Hard drives are supposed to read/write/respond within specific parameters. If the drive stops operating within these parameters, it usually means that the drive is failing, and therefore your information should be backed up, and your drive should be replaced. Once you back up your data, you can contact HP support to get the hard drive replaced.
Mar 03, 2010 | HP Computers & Internet
It says imminent failure but wasok till i updated to sevice pack 3
The imminent drive failure notification is from the S.M.A.R.T. feature on your hard drive. It means your drive is not working according to specs. More that likely when you installed SP3 the drive was accesses more than normal and the controller electronics noticed the errors. The Hard drive can detect when it is operating out of the range that is ok. You need to backup your data and replace your hard drive as soon as possible to prevent data loss.
I hope this help, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
Jun 28, 2009 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
SMART HARD DISK ERROR BACK
hi
SMART Hard Drive detects imminent failure. Your hard disk drive is detecting an imminent failure. To ensure no data loss, backup contents and replace this hard disk
Jyo
Jun 19, 2008 | Computers & Internet
S.M.A.R.T Command failed
It means that the hard disk SMART monitoring system has detected problems serious enough to warn you of the growing possibility of hard disk failure. Sometimes a drive will last quite awhile after this first notification, but there is a good chance of imminent failure, in minutes, hours, days, or weeks. You should immediately look into installing a replacement drive.
You should immediately copy any important data off the drive, perform full backups, and limit use of it.
If you can install drives yourself, a new hard disk (especially Seagates) usually come with software to clone your existing drive to the new drive. Otherwise, a repair shop will be able to do it for you.
I recommend also purchasing a drive enclosure for your old drive. For whatever life it still has, it will be a good backup of your system.
Dec 06, 2007 | Samsung (SP0411N) 40 GB Hard Drive
Computers & Internet Logo
David Payne
David Payne
