Question about Acer Computers & Internet
Acer aspire 5043wlmi laptop starts but know function of lcd but works on desktop monitor
    Scholar:
  • 83 Answers
The computer's power management system automatically dims the screen when using battery power, which is one of the power-saving features.
To adjust the brightness:
  • Hold down the Fn Key located at bottom left of your keyboard next to the Ctrl key, and adjust the screen brightness using the left/right arrow keys located at the bottom right of the keyboard.
If that's not it then
A dim or dark screen does not necessarily mean a bad inverter! It could be a faulty lcd backlight bulb, inverter cable, inverter, or in some cases a motherboard failure. If your still under warranty then I would get Acer support on the phone and see what they can do.
An Inverter converts direct current (DC) to alternating current (AC).
Posted on Jul 01, 2008
I have got acer aspire net book size is 8.9 inch. Ca i connect it to external monitor
Hi.
Sure you can with a standard VGA video cable.
Maybe you will have to change your screen resolution to get the best display layout.
Hope it helps!
Feb 10, 2011 | Acer Aspire One AOA150-1784 Netbook
Acer aspire battery does not recharge how to open
Are you trying to open the battery? is so then please don't it can be very harmful,
Does the system work when still plugged in? If so then the battery is bad, If it does not then there is an issue with the power port usually the solder breaks loose and is a quick repair for a technician,
However opening the laptop itself is virtually impossible to explain on here... Remove the battery sometimes there are small screws.
On the bottom of the laptop screws are usually grouped by letters or symbols.
Keep all like screws together. If there is anything we can do let us know,
Nov 08, 2010 | Acer Aspire 5043WLMi (LXADX05009) PC...
Hello, everythiing works great with my Acer Aspire 5610-4648, however the display will work fine for a while and then start to lines or fuzy and freeze. Some times it does't happen at all, others it you...
If the External LCD Monitor display is working fine, then you computer has to be serviced as the issue is with the laptop LCD screen.If your system is under warranty,please contact Acer.
Oct 24, 2010 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610 LCD backlight problem
my laptop is acer extensa 4620 problem is web cam is not working what will do
Nov 05, 2009 | Acer Aspire 5610-4648 Notebook
My Acer Aspire 1681WLMi's monitor does not work, LED showed the functional hard disk is also not light up, help me.......!!!!!!!!!!
May be the LCD screen is not working fine. Try to put external monitor with the laptop and see if you are getting display on it.. It will make you sure that the driver is fine...
Aug 30, 2009 | Acer Aspire 1681WLMi Notebook
Hi i've been using this laptop for over a year
If you can connect your VGA output to a regular desktop monitor and it works during the startup process, then it is probably you LCD screen. There is no way to know for sure that it is the backlight unless you replace it.
Jul 16, 2009 | Acer Aspire 6920 Notebook PC
Acer aspire ase380 power switch problem
do you get the self test screen on the monitor. is so it is not communicating with comp. bad video port most likely
Jun 27, 2009 | Acer Aspire E380-UD420A (ASE380-UD420A)...
No LCD connectivity
Hello, I am using a Viewsonic lcd projector with my new Acer Aspire One. I did not have connectivity off the bat. Here's what I did: 1. Downloaded driver (unsigned, not the signed version worked - ie not os-specific) for the lcd projector to the Acer. Restart Acer. 2. With lcd projector connected to Acer, toggle function key & F5. But then, continue holding down the function key. A screen pops up with icons for laptop, laptop/monitor, dual monitor, and lcd projector. You continue to hold down the function key and then press the F5 key to move to the desired device. I had to repeat the same process to restore my Acer screen to the original proportion when not using lcd projector. I'm not sure if both steps 1 and 2 are necessary, but I did it simultaneously, so I'm not sure of the origin of success.
May 22, 2009 | Acer Aspire One PC Notebook
Broke lcd screen on laptop; need update to networked desktop, how?
If I understand correctly, you need to update your laptop??
Or get some files off it??
Anyway, connect an external monitor to your laptop and you can work on it that way. You may need to push a special function key to switch monitors. Check your keyboard.
In any case, connect the external monitor and turn it on, then power up the laptop.
May 10, 2008 | Acer Aspire 5610-4648 Notebook
Backlight in monitor not working
try to press fn + any function key that has the sun logo or to bright your monitor.
if that doesn't work bring your laptop at the service center because the lcd is having a problem
Apr 10, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
254 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
