2002 Cadillac Deville Logo
Posted on Jul 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shaking all the time,really get`s noticable about 50 mph
  • j_doja Sep 27, 2008
    Have a 2004 cadillac deville dhs. With stock rims 6 months after purchas steering wheel began shaking at 45mph to 75mph. Gets better towards 70mph. Dealer does not know what it is. I have gotten the wheels balanced and all that. Did you figure out what to do to fix your issue?
    Email me - [email protected]
Anonymous
Level 3:
Master:
  • Master 726 Answers
  • Posted on Jul 01, 2008
Anonymous
Master
Level 3:
Master:
Answers
726
Questions
5
Helped
257085
Points
1674
Hey there if you have bad shaking when your traveling you might need a wheel balance or a wheel alighnment thats the most cause
1helpful
3answers
1helpful
I have a 1996 Chevrolet caprice classic ad it starts to shake at 45 mph not so much when you're on the gas but when you get off the gas at 50 to 60 mph it shake really bad I'm not sure what to do
How old are your tires ? have one out of round or busted cords inside , maybe a wheel weight feel off . take it to the tire shop have the balance checked !
2answers
On 98 caravan 2.4 it starts to wobble at 40up to 50 mph mostly when accelerating when speed reached smoths also smooths out after 50 mph alll new including valves. could bad wires cause this?
How old are the good tires? These speeds usually mean belt or balance problem with tires...If new tires, they need to be re-checked for balance...and not out of round...also check for bent wheel...due to chuckhole? Sometimes a bent steel wheel can be hammered straight...hope this helps.
2answers
My 2004 Rendezvous starts shaking at 35 mph and stop at 50 mph. If I let off the gas the shaking stops. whats wrong
This may a serious problem that may cause you to have a bad accident. Please take into a service shop ASAP and have them check it out.
2002 protege periodically shakes between 50-60 mph, then stops when go less than 40 mph
possible a wheel alignment possibly from the rear wheels and loose/worn suspension rubbers
Shaking violently
ckeck your c.v. axles
1helpful
Vibration in Cab of Truck
sounds like a bent wheel rim
1996 Ford explorer 6 cyl. shakes at 45-50 mph
If the engine is misfiring and that is the source of the shaking then the check engine light will be flashing like crazy, other wise it is not the engine causing this, I know was a Ford tech for 25 years.
2helpful
Shaking & rattling above 50 mph
have a tire shop balance your front tires.
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
