Question about JVC Televison & Video
I have a JVC AV-32850 TV that just stopped working. It was on and then went blank. The red LED ON Timer now flashes on and off, and sometimes there is a clicking sound. I checked the outlet, and it is fine. Unplugging and plugging back in does nothing. Thanks, Ted
  • 1 more comment
  • tbuntjer Jul 01, 2008
    It flashes continuously. It does not stop. I have unplugged it. I would prefer to fix it myself, but would be open to having it serviced. The TV is about 10 years old, but it had not given me any problems until now.
  • tbuntjer Jul 02, 2008
    Thanks for your help. I have located the capacitor on the board. It seems difficult to get at the capacitor. The circuit board has components and leads attached to the cover (bottom and back) and the front of the television (AV-32850). I thought I would try to spring the plastic clips holding the circuit board in place and rotate it enough to do the soldering. Any suggestions? Thanks, Ted
  • tbuntjer Jul 04, 2008
    Changing out the C926 Capacitor solved the problem on my JVC AV-32850 TV. The television works fine now. The hardest part was getting the TV apart to access the circuit board and putting it back together. I appreciate the help.
    Genius:
  • 1,011 Answers
Sir,
The component is the C926 (labeled on the bottom) capacitor near the center of the circuit board chassis. It is a large cylindrical capacitor just to the right of center as viewed from the rear. De-solder it out and replace it with a 1000uf 35v or 50v capacitor from Radio Shack. The cap. you buy from Radio Shack will be axial leads, while the cap. you replace will have radial leads. Don't let this bother you just bend the leads to fit the holes and it will work fine. Pay attention to the polarity marking on the circuit board and the capacitor. You need to have a little experience in how to solder leads on a circuit board. If you have neve done such work, find someone who has. It is not difficult but you don't want to fry the component or screw up the solder joints of other nearby components.
"MAKE SURE TO BUY THE CAPACITOR WITH THE TWO WIRES COMING OUT OF THE SAME END OF THE CYLINDER... I.E. CAPACITOR WITH RADIAL CONNECTION)"
On a call to a JVC certified repair shop, they told me they're not sure what the problem could be, but I would be looking at $300-400 repair. I replaced the C926 capacitor for under 2 dollars and now it works like a charm! Sounds like JVC indeed does have a problem with these models.
Your may also contact customer service at (800) 252-5722
Thanks
good Luck
"Don't Forget to rate the solution"
Posted on Jul 01, 2008
  • 4,472 Answers
How many times does the light flash or for how long does it flash? Are you trying to service this yourself? or open to the suggestion it may need servicing? How long ago did you purchase the unit?
Thanks,
lee
  • Lee A.
    Lee A. Jul 01, 2008
    It could be a power board issue. The tv is a CRT tv, so they are relatively cheap to have serviced or even replace. You could take the casing off and inspect for any bad capacitors or solder joints but I would recommend leaving it to the professionals as it should most likely not be a costly repair, and if so 32" crt tv's are relatively cheap.
    Thanks,
    lee
  • Lee A.
    Lee A. Jul 04, 2008
    I hope you found my solution helpful and will have a moment to rate it accordingly. Glad you got it solved.
    Thanks,
    Lee
My tv went blanck
Bulb lamp is most likely out, replace and clean all fans for cooling also.
Apr 16, 2010 | JVC AV-48WP30 48" Rear Projection...
I have a JVC model AV-32750 TV. We were watching TV and suddenly the picture went out and the red light on the on off button in the front panel started flashing and clicking. The TV will not turn back on....
Unplug the unit for more than just one minute, let say at least half an hour. Let me know how many times the led blinks, probably the unit need repair.
Oct 13, 2008 | JVC Televison & Video
JVC 65 inch AV-65WP55 tv, the color red is failing
The tube is old. You need to contact a service center. He may try to boost it from inside. If it doesn't work, then need a new tube.
Jan 09, 2010 | JVC AV-65WP55 65" Rear Projection...
When changing the AV mode on my remote, the screen suddenly went blank, and the green power indicator on the TV went from green to flashing red. Pressing either the power button on the TV remote or...
Would be great to know the Make and the Model # and if its still under warranty as I strongly believe you are having an issue with the main power supply.
Blessings always,
A/V Media Tech guy
Dec 01, 2009 | Televison & Video
My JVC AV-48WP55 only blinks the green led when plugged in. This happened after a power surge, during a thunder storm.
Have you tried unplugging the tv and letting it sit for a while then plugging it back in?
also.. sometimes i have seen appliances that will flash the power light if an internal fuse has blown to indicate a problem. open it up if you feel you want to and check for a fuse around where the power cord comes in teh tv.
Nov 18, 2009 | JVC Televison & Video
Jvc tv on button flashing on av 48wp34
Use remote, sounds like Tv is in child lock
Dec 21, 2007 | JVC AV-48WP30 48" Rear Projection...
AV 50D501 JVC projection T.V.
sounds like a bad connection in the deflection circuit. you need a repair tech
Dec 16, 2007 | JVC AV-56WP30 56" Rear Projection...
Jvc hd61z575 61in. rear projection tv won't come on
ok you have defective power supply in hotside section! maybe they have abnormal oscillation!
Oct 11, 2007 | JVC HD-61Z575 61" Rear Projection...
JVC AV-48wp74 Red, Blue, Green
no you did the right move but now you align the new pc board ,try to get the service in to enter the convergence alignment section,on most jvc;s it sleep timer ,disply&video status to enter try it but if your not sure of that you can perform the alignment ask a tech to do it. on the remote certain keys do special functions and you need to know what they do or you might make it worse.
Aug 18, 2007 | JVC AV-48WP74 48" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top JVC Televison & Video Experts
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
