Frost on the AC Unit - Heating & Cooling
  • scarel Jul 01, 2008
    Now the outdoor unit work but the blower inside is not blowing any air through the vents
    Novelist:
    Champion:
  • 230 Answers
Plugged air filter
low refrigerant
blocked supply or return vents
incorrectly sized unit
failing compressor
restricted line set
plugged metering device
thermostat turned to low
stuck contactor relay
Failed circulatory blower motor
Failed indoor blwr run capacitor
improperly wired (or damaged) control wiring
That is about all I can come up with for your topic. Maybe we could narrow things down a little with some more information from you. Thanks!
Posted on Jul 01, 2008
  • Don Berry Jul 01, 2008
    We are starting to narrow things down a little. Does it sound like the inside fan is running? If it is running then that most likely the evaporator coil is frozen into a large block of ice. This will cause a reduction in air flow. Let me know.
It cools great when first turned on. After so many hours of cooling it stops cooling
Have you checked up in filter area at ceiling to see if fins are frozen or frosted bad? If they are dirty, they can cause frost/ice and AC goes in to fan only until frost/ice is gone. When did unit actually get a good cleaning last? Too many registers closed or blocked can cause freeze up as well. Does this unit have ducted or non-ducted system?
Aug 18, 2013 | Dometic Rooftop RV Air Conditioner
Ac icing up
Hello Paul - I understand your air conditioner is icing up. However, could you please advise me if the frost is occurring on the entire unit, a partial part of the unit, and/or the coils? With this information I can better address the issue. Thank you and I look forward to your response?
Jul 01, 2013 | Electrolux Refrigerators
My Honeywell AC unit doesn't seem to be working properly. It will not retain a temperature. I set the thermostat to hold a temperature of 70 degrees. Room temp still reads 74 degrees. Something is working,...
The frost on the pipe indicates you have a dirty filter, dirty evaporator coil, Blower not running at the proper speed (to slow) or you are low on refrigerant.
Jun 29, 2010 | Heating & Cooling
Trane XE 1200 ac The outside fan stopped
unless you have a meter youneed to see if the unit is asking the fan to turn on. if so the fan (which i doubt) maybe gone bad or the starting capasitor for the fan... is there anyway of checking the voltage to the fan
Jun 22, 2009 | Heating & Cooling
Window AC question, normal or abnormal?
Unit low on Refrigerant. Need someone to charge system.
Jun 10, 2009 | Heating & Cooling
The Intertherm AC Model B3BV-030K-A is blowing warm air
If you don’t see any frost on the suction line or big line on the furnace
(that goes from the furnace to the outdoor unit) and the filter and coil are clean then you are probably low on refrigerant.
Apr 14, 2009 | Heating & Cooling
Frost build-up
Two things will cause this: low air flow or low refrigerant. If you are in cooling mode then check your filter and indoor air flow. If that's good then you'll have to get a technician to check your refrigerant. If it's low it has a leak that needs to be fixed.
Mar 30, 2009 | Heating & Cooling
Ice or frost on the inside coils of the ac unit
Reduced or no airflow, Evaporator may be dirty. Low on freon.
Jul 31, 2007 | GE AJCQ08ACB Air Conditioner
Heating & Cooling Logo
127 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
