Question about Haier Heating & Cooling
This ac blows air not cool air.Blows hot air.
  • Anonymous Mar 29, 2014
    no cooling compresor is on but air is comming hot
    Novelist:
    Champion:
  • 230 Answers
If the fans and compressor are running then it is low on refrigerant.
Posted on Jul 01, 2008
Car gets hot when Idle
You might check your cooling fan at the radiator; it may not be running. If it's not, track it down (fuse or thermal switch) and fix it!
Aug 07, 2014 | 2007 Suzuki XL7 AWD
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Ac blows cold then hot air
Is the compressor running when it blows hot air ?
Jul 31, 2012 | GMC Sierra 1500 Cars & Trucks
Aiconditioning blows hot air Ford Focus 2004
Your valve that shuts off the hot water to your heater core is not closing.Your AC is running but it is trying to cool down 200Deg. air.May be a issue with the heater/AC contol in the dash or the mixing valve stuck open.
Dec 31, 2009 | 2004 Ford Focus
Hot air blows but cools down in 15-20 seconds.
You likely have a restriction in the heater coolant hose circuit - perhaps a coolant control valve not fully opening, or a kinked hose.
Insufficient coolant volume is flowing to keep the heater core hot.
Try back flushing the heater core system with a garden hose to check flow.
Nov 13, 2009 | 2003 Audi A4 Cabriolet
AC cools then blows hot air, tempature needle goes up & down
Sounds like the thermostat is trying to stick,and is causing the engine to over heat,therefore condenser is not cooling the freon down enough to cool.Have the thermostat changed and the cooling system bled out,this is most likely the cause.
Aug 29, 2009 | 2005 Lincoln LS
Ac blows hot air
If your a/c blows only hot air you need to have it charged. Hope this helps to get you cool
Jul 24, 2009 | 1997 Mercury Mountaineer
When on AC the air blows hot, when on heat the air blows room temprature
This is a wiring issue or you have a heat pump and the reversing valve is stuck.
Jun 03, 2009 | Honeywell Electronic Programmable...
Automotive AC Prob
Automotive AC is a complex thing to resolve. I have rebuilt many and have seen what it takes to make them work correctly. Now send me make, model, year and engine type and from there I can help you solve your problem. Thanks, Sea Breeze
May 30, 2009 | Heating & Cooling
2002 New VW Beetle is only blowing hot air out of vents even when set on cool. I was driving and I made a turn at an intersection and all of a sudden the cool vent air turned to hot air like I had the heat...
On the bottom of the air unit is the lever that changes temps. It likes to fall out of place.I propped mine back with a piece of half-inch copper pipe a couple of years ago.Remove glove box then panel on front side of console to access.
Apr 09, 2009 | 2003 Nissan Altima
Heating & Cooling Logo
144 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
