You need a new Print head, it is a common problem with Kodak printers:
Contact Kodak:
United States Telephone Support
All-in-One Printer Phone Support
Live phone support is available in English and Spanish at 1-800-421-6699, 9 A.M. to midnight Eastern time, 7 days a week.
The expected wait time for phone support is 15 minutes.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: color ink cartridges empty, printer wont continue to print
select print black only from the print or page set-up.
SOURCE: Printer won't print
It always helps to replace with the correct brand as cheaper versions do fail, also if you had replaced it with a BC-20 from Canon, the supplier may replace it for you. It would be a good idea to trust the printer at this stage, try a Canon BC-20
SOURCE: changed black ink cartridge to LD brand. Now
Canon printers do not like non Canon inks. Maybe other printers have similar issues but it seems that Canon is particularly finnicky.
SOURCE: Black ink cartridge is new but not printing
Was the code of the cartridge you put is correct? if not then replace it.if it is right, then check the nozzles, the printer heads and clean. some printer is equipped with cleaning tools software that might help you.
SOURCE: Printer will only print in color...will not print
There are Generic brands that says it is for your system but in reality, the don't work.
I have a MFP360 and the same thing happens. I had to buy original and now my printer works very good
